Old 05-22-2013, 08:43 PM
KingSilverback KingSilverback is offline
The Silverback
Mein Auto: 2006 750Li
Re: Aftermarket backup cameras
PAPER are you tryna be helpful or? I'm lost here. What Rob said is what I encountered. I'll check the wires when I get home Rob thanks for tryna help
Old 05-22-2013, 08:52 PM
PAPER's Avatar
PAPER PAPER is offline
CRISP & CLEAN
Mein Auto: Ford Pinto
Originally Posted by robin24k View Post
That's not being helpful. Even with a background in EE, it took me a while to understand the document, and I'm still not sure what is the color of the reverse lamp's positive lead.
On page 6, it says to splice into a white/yellow wire of the "registration plate light," so that should be ground. On page 9, it says to connect the power supply to the red/white X1889 cable, so that is probably positive.
KingSilverback, can you check what the reverse lamp wire colors are? One of them should be red/white if I read the document correctly.
So hows the weather out there in WASHINGTON ???
Old 05-22-2013, 10:48 PM
The Silverback
smfh...
Old 05-28-2013, 12:10 PM
The Silverback
Those are the wires that plug into the reverse bulb cluster, there is no red white
Old 05-28-2013, 01:33 PM
Robin750 Robin750 is offline
Mein Auto: 2013 BMW 750i
Sorry, I really couldn't find anything useful in those PDFs that PAPER posted.
Do you have a multimeter? If so, the easiest way to verify would be to put the car into reverse and check the voltage of those pins. White is probably ground, so you just need to probe the other three.
Unfortunately, I am out of town and cannot check on my car. My guess is yellow/black, but that is pure speculation and I wouldn't recommend haphazardly splicing into it before verifying voltage.
Old 05-28-2013, 01:48 PM
The Silverback
Sounds good, I'll grab a multimeter after work and do what you recommended, I didn't wanna splice into random wires like you said lol
Old 05-29-2013, 12:23 PM
The Silverback
For anyone else who might wonder, the white/yellow wire is the positive lead for the reverse light 12volts. I used a multimeter to verify this. Also the brown black wire puts out 14volts and is always on.
Old 05-29-2013, 12:29 PM
Good thing you checked with a multimeter.
Old 05-29-2013, 12:38 PM
The Silverback
Yeah the naviks installation instructions had told me to splice into a brown wire but I was skeptical that's why I asked
, I woulda spliced the wrong wire
Old 05-29-2013, 03:39 PM
PAPER's Avatar
CRISP & CLEAN
I looked at a 745li today that has a backup camera & it
was connected to a green wire .
Old 05-29-2013, 04:00 PM
as3070971 as3070971 is offline
Mein Auto: 2002 bmw 745
I have a 2002 745li with the naviks. There is a blue and a brown wire going to the reverse light. Spliced into the blue wire. Always thought brown wires were the ground on bmw. Works fine but also had to add the relay to make it work.
Sent from my SGH-T999 using BimmerApp mobile app
Old 05-29-2013, 05:06 PM
PAPER's Avatar
CRISP & CLEAN
now that you mention relay , I do remember there was 2 taped together
& the wire's on them we're brown with white line , blue , & green . I
think there was 1 or 2 more but I can't remember sorry .
I should have pulled my Damn phone off the charger & taken a pic .
Old 05-29-2013, 05:36 PM
The Silverback
So I guess the safe thing to do regardless is to use a multimeter. Seems the wire colors differ in some 7 series
Old 06-13-2013, 05:04 PM
mws mws is offline
Mein Auto: 760Li, F250 V10, Ex 7.3L
Thanks, as3070971 and KingSilverback. I am hot to do this mod and the post could not have come along at a better time.
basically, if I can get the wife driving the 7 more, I can off her Lexus and buy an E62 M6
Old 01-19-2014, 09:56 PM
mybmw408's Avatar
mybmw408 mybmw408 is offline
Mein Auto: BMW 750i
I just ordered the Naviks unit and it shall be here by January 27th. I cant wait to install the rear view camera.
Old 01-20-2014, 10:18 PM
Joe750's Avatar
Joe750 Joe750 is offline
Mein Auto: 750li
Is there a link ? So I can check it out ?
I'm interested ..
Old 01-20-2014, 10:21 PM
mybmw408's Avatar
Mein Auto: BMW 750i
http://bit.ly/1amdNcS
Old 01-21-2014, 09:56 AM
mudd746 mudd746 is offline
Mein Auto: 05 745li
Just put in a alpine hce-c305r active rear camera in mine. I post a few pics later. Figured I should use a technical advanced camera for this type of car
05 745li, 22" Asanti AF211 B4 Alpine White 22x11,22x9.5.
Old 01-21-2014, 10:03 AM
Joe750's Avatar
Mein Auto: 750li
Don't forget to post pics lol
Old 01-21-2014, 10:35 AM
mybmw408's Avatar
Mein Auto: BMW 750i
So you have to install naviks then connect the alpine camera??? Or just purchase the alpine unit by itself??looks like you have to push a button to view camera.
Old 01-22-2014, 10:37 AM
Mein Auto: 05 745li
I installed a PAC bmw video interface it adds back up, 2 aux inputs, and one output.Click image for larger version
ID:	418375Click image for larger version
ID:	418376Click image for larger version
ID:	418377Click image for larger version
Old 01-22-2014, 11:18 AM
mybmw408's Avatar
Mein Auto: BMW 750i
I installed a PAC bmw video interface it adds back up, 2 aux inputs, and one output.Attachment 418375Attachment 418376Attachment 418377Attachment 418378
I thought you installed the alpine one????
What camera did you use???
Old 01-22-2014, 01:32 PM
Mein Auto: 05 745li
It is the alpine hce-c305r. It's a pretty sweet camera it has 4 different views and it will detect and locate moving objects behind you. I removed the light assembly to mount it inside the panel. I wanted it to look as factory as possible. The button is in the lower drawer in the dash but I need to make a panel for that. I'll post some pics of that when I finish that part
Old 01-22-2014, 01:41 PM
mybmw408's Avatar
Mein Auto: BMW 750i
Okay now I understand now, since you gave me partial answers....A+B=C. You used the PAC A/V converter then plug-in the Alpine unit to it.
Old 01-23-2014, 12:36 AM
B7Alpina B7Alpina is offline
Mein Auto: Alpina B7 N62
Whats your set up? naviks or naviteek
with this camera?: alpine hce-c305r
