E46 (1999 - 2006)
Old 05-02-2013, 01:21 PM
SPDSKTR SPDSKTR is offline
I'm a DlCK! So what?
Mein Auto: E46 ZHP TS2+ Coupe
I believe I'll be replacing my clutch and flywheel this weekend...
What I have:
1) OEM Sachs clutch
2) OEM Luk flywheel
3) Detent springs
4) Rear main seal
5) Pilot bearing
6) Throwout bearing
7) Driveshaft support bearing
8) Input shaft seal
9) Tail shaft seal
10) All necessary bolts
11) Liquid Wrench
12) Beer
13) Xanax
14) Assorted loaded handguns
To be honest, I'm pretty effing intimidated. I may have to hunt down a Bentley manual, but the person who agreed to help me has done clutch swaps before.
Old 05-02-2013, 01:27 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Dude!
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-02-2013, 01:34 PM
ahull's Avatar
What about giubo? Extra exhaust studs n nuts when they disintegrate? Pivot pin and fork spring? Selector rod seal? Fat spliff?
Old 05-02-2013, 01:40 PM
Yes... Guibo and differential bushing are on the list, too.
I need to swing by the BMW parts place and get more exhaust bolts and nuts. I believe I have the selector rod seal. Pivot pin and fork spring, I'm unsure of. I'll have to check when I get home.
Old 05-02-2013, 01:50 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
You should just drive to Shads house. Park your car behind his so he can't get out and leave the clutch parts on his doorstep.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 05-02-2013, 01:58 PM
OfTheLost's Avatar
OfTheLost OfTheLost is offline
Mein Auto: 2000 328i
I just laughed out loud at work. We've got a big car guy here and the running joke is that if you want something done to your car, just drive over to his house and start working on it. He will eventually come outside and takeover.
Old 05-02-2013, 02:03 PM
JJ3699's Avatar
JJ3699 JJ3699 is offline
Send a message via AIM to JJ3699
Mein Auto: 2003 325i
YES
.................BMW 4 LIFE.....................
Old 05-02-2013, 02:25 PM
I was lucky to even get ahold of him today, and that was to pick up the axle for my girlfriend's car!
Old 05-02-2013, 04:13 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Don`t forget the splined clutch alignment tool....
Have you ever removed a pilot bearing ? Here`s a relatively inexpensive puller if you need one :
http://www.amazon.com/Mountain-MTN90...=5336432695-20
The road goes ever onward....
(R.I.P. Jever)
Old 05-02-2013, 04:17 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
I printed out the entire tech article from Pelican to do one of our E36s: http://www.pelicanparts.com/bmw/tech...ch_Replace.htm In the comments section, they mention that there are a few differences between E46 and E36, especially some torque specs.
It would also be a good time to replace the plastic shifter linkage bushings and even the shifter arm bushing. Have a 3 ft. long socket extension (plus others) to reach the upper transmission mount (e.g. bell housing and starter motor) screws.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 05-02-2013, 05:54 PM
Gryphon's Avatar
Gryphon Gryphon is online now
The Boss of Nobody
Mein Auto: 2005 ZHP, Wife's Prius
Re: I believe I'll be replacing my clutch and flywheel this weekend...
If you're dropping the trans, replace the detent pins
Arthur John "Destroyer of Sleep"
Born 02-24-11
Sean David (has more rolls than a bakery)
Born 06-22-16
Old 05-02-2013, 07:59 PM
I need detent pins, the pivot pin (same thing?), and... fork spring (I have three detent springs). What else?
How else can I remove the bearing if I don't have a puller? Screwdriver and elbow grease?
[Sent from my Galaxy Nexus.]
Old 05-02-2013, 08:25 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Pefect time to consider the short shifter kit?
PM me and I'll hook you up with some more info for the job.
Old 05-02-2013, 08:32 PM
Fast Bob's Avatar
Keeping it surreal
Depends on which type of bearing you have....if it`s the needle-bearing type, you`ll need a puller, no two ways about it.
If it`s the solid bushing type, you can take the thickest, heaviest grease you have on hand, and pack it in *tightly* through the hole in the bearing, filling the *entire* void behind the bearing....NO air bubbles !
Then, take a short length of round steel rod that will *just* fit through the bearing`s hole, insert one end into the hole, and begin wailing on the other end with your 3-pound Baby Sledge. If you have enough heavy grease in there, the hydraulic pressure will get behind the bushing, and push it out.
Primitive, but effective if you don`t have a puller on hand.
(R.I.P. Jever)
Old 05-03-2013, 08:23 AM
ahull's Avatar
Pivot pin is what the fork rides on. Stock is plastic I think.
#6 and #7(spring)
http://www.realoem.com/bmw/showparts...93&hg=21&fg=05
Sometimes you're lucky and can just pull the pilot bearing out with a finger, but be prepared.
Old 05-03-2013, 09:29 AM
I already have the UUC SSK. Thanks, though!
Old 05-03-2013, 10:25 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
Read this and watch the video:
http://blog.bavauto.com/11939/bmw-di...nstall-how-to/
Old 05-04-2013, 09:06 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Sorry guys, my life has been way too busy for anything car related. Hell, my own car has had the brake pad warning light on for two weeks. My real job is a bear right now.
Old 05-04-2013, 09:40 AM
I figured as much. I was honestly getting worried something happened to you.
Want to come help us? Just got the car on jacks.
Old 05-04-2013, 09:47 AM
Here we go...
Bonus content...
Old 05-04-2013, 10:26 AM
Well... due to the late start and lack of know-how, we're tackling other projects (RTABs).
Old 05-04-2013, 11:16 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
So about that supra...1JZ 2JZ? Owner willing to trade for an 03 330Ci. Lol jk I love cruising in the bimmer too much.
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 05-04-2013, 12:29 PM
RTABs done. Profanities were used. Good times were had.
Old 05-04-2013, 02:29 PM
Fast Bob's Avatar
Keeping it surreal
Now, that 2JZ swapped into an E46 would be interesting....
(R.I.P. Jever)
Old 05-04-2013, 02:46 PM
Damnit Bob don't temp me. I am trying to convince myself to keep the 46 "stock" and buy an e30 to give hell.. now you put these ideas in my head...
