E36 (1991 - 1999)
Old 05-02-2013, 03:02 PM
Jwerner2 Jwerner2 is offline
Mein Auto: 96 328
Anyone else with Bilstiens?
Got this car used and the passenger side sits lower. Can't figure out which way to spin the perch to raise it up a bit. If anyone can help with such stupid question thanks. Again its the passenger side, if it makes any difference.
Old 05-02-2013, 03:12 PM
LordlierPie7781 LordlierPie7781 is offline
Mein Auto: 93 Dinan S3, 325is base
i am pretty sure BMW's sit higher on the driver side from the factory.
Old 05-02-2013, 03:42 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Controversial.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-02-2013, 04:36 PM
Mein Auto: 96 328
Okay so maybe I'm stretching the truth. It's not just a bit, its a good amount. Enough to make me rub on a E46 17" with a 205/55 tire. The cars low but not super low. I can go a lot lower on these threads. Fenders rolled and sorta pulled. Gotta get new ones. The kid before me twizzled them up.
Old 05-02-2013, 04:41 PM
petriej's Avatar
The shocks do not determine ride height, they dampen the springs so they settle quickly.
Those wheels/tires seem awfully large for an E36.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-02-2013, 04:42 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yeah, a 55 series tire on a 17" wheel is pretty freakin' tall. It should be down at 40 or 45.
1998 BMW 328is
1966 Pontiac GTO
Old 05-02-2013, 05:09 PM
Mein Auto: 96 328
Sorry bout that. They're 16's 16x7" off of an e46. I got 17's on the brain right now. I'm looking for a set of 17's.
I'm not talking about the damping, I'm talking about the ride height. They are adjustable Bilsteins. Though I'd like to know how to adjust that in the front too.
Old 05-02-2013, 05:31 PM
Mein Auto: 96 328
When I screw it upwards it looks like the spring is compressing. That's why I ask.
Old 05-02-2013, 05:34 PM
petriej's Avatar
They might be adjustable coilovers. If that's the case, you need to find out if it is pin or slot type, and by the appropriate spanner. Then you can adjust the heights.
Check here.
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-02-2013, 05:49 PM
Mein Auto: 96 328
I have the tool and it spins fine. I'm confused in which way to spin it. When I spin it up the car doesn't appear to be getting higher just looks like the helper spring is compressing. Everything spins, springs and all.
Old 05-02-2013, 06:02 PM
Mein Auto: 96 328
Now I figured that my caster on that sides out. I spun them down all the way now that I figured it out and made sure to rotate the perch on each side the same amount if times. Still sat lower on the passenger side. Then I noticed my wheel sits farther back towards the door than the driver side.
I also found out that's where my wheels rubbing.
What could cause my caster to be so out of whack?
Old 05-03-2013, 06:02 AM
Mein Auto: 96 328
At lock with the ride height on this side way higher than the driver side. Still rubs pretty bad. Don't mind the dirt. That's become the last thing on my mind.
http://postimg.org/image/efcvds2or/
Old 05-03-2013, 06:16 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
I have Bilsteins as well. Damn awesome shocks!!!! Same with Koni. It's so hard to choose between the two.
As far as the way the car sits, it sits higher on the driver's side than the passenger's side, to compensate for the weight of the driver. Now everyone has their own opinions to justify their broken cars, but that is usually how they are.
And believe me when I say that I have no idea what I am talking about.
Old 05-03-2013, 06:38 AM
Mein Auto: 96 328
I understand that much but that does not answer my last question on my caster issue. What could be worn or bent to cause this? I know I most likely need bushings but nothing is bent or broken. Plus I need bushings all around so why is this issue only on the one side of the car?
Old 05-03-2013, 07:45 AM
hnaz's Avatar
BMW CCA Member
Did you put the car on an alignment rack yet? Check the shock towers? How about the springs and top hats?
Old 05-03-2013, 08:13 AM
petriej's Avatar
Do you have castor plates?
GGC BMW CCA #443004
Join the BMW CCA!
Old 05-03-2013, 07:32 PM
hornhospital's Avatar
D'oh, You Kids!
I have castor beans! (NO I DON'T, I'm kidding, and I know nothing about making ricin from castor beans!)
Castor=/=caster.
Quotes to live by:
Old 05-03-2013, 07:41 PM
Mein Auto: 96 328
I haven't gotten it in the rack yet but I plan on it by the end of the week when I have off. I'm trying to just diagnose the obvious and try to save done time and money. Everything else has been checked.
Old 05-03-2013, 09:49 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Bilsteins are awesome!
/thread
