Old 05-02-2013, 04:54 PM
up2parr24 up2parr24 is offline
Mein Auto: 330i E90
Passenger Low Beam Malfunction Help/Ideas?
History:
I have a 06 330i e90 and the passenger low beam malfunction error is on my iDrive along with the passenger low beam being out. The rest of the headlight works properly. Two months ago I had this issue, I replaced the ballas/control unit, the bulb, and the wire that connects those two. It fixed the issue after install, then next day it went out on startup and then came on in mid drive about 15 seconds later. After that its been good for a couple months until past two weeks. Past two weeks I noticed flickering and then it'd stay on. The last couple days, no flickering and it won't come on. So, I know my ballast is good, the bulb is good, and the headlight does function properly... Any ideas? Looking at the diagram part numb 63127189312 could be a possible issue but that looks like a electric module for the adaptive parts and not the actual low beam. Here's a link to see the diagram, its part numb 3: http://realoem.com/bmw/showparts.do?...63&fg=05&hl=14
Any ideas? Thanks for reading.
James
Old 05-02-2013, 05:58 PM
Banned
Mein Auto: 2007-335 HTC
Maybe re- check the electrical connections, on my 71 british car first rule of thumb is check all electrial connections.
Old 05-02-2013, 06:15 PM
Mein Auto: 330i E90
Thanks. I will recheck and post tomorrow. Anyone else feel free to please chime in...
Old 05-04-2013, 10:55 AM
Mein Auto: 330i E90
Fixed this issue!
So I checked the Volatge to my headlight harness and it was a constant 12V. So I then narrowed the problem down to the headlight being the issue. I JUST recently replaced the ballast, bulb, and ballast to bulb wire which is a pretty time consuming job since you have to remove the headlight which requires removing the bumper, and is more complex if you have headlight washers. So my first idea was to check the harness that powers the ballast (small plug with a black wire and yellow wire). I made sure it was connected, and I noticed the wires were sitting against the back of one of the components of the headlight (high beam bulb I believe). The back of this component is metal, so I thought maybe the wires sitting against it were shorting the power to the ballast. Moved the wires off of this piece, turned on headlights and BAM, came on and works perfect now.
Conclusion: I wasted 4 hours and $350+ removing the headlight and buying/ installing new ballast and bulb. The single issue causing this problem was the wires supplying power to the ballast were being shorted by resting against another component in my headlight.
I've seen several issues for "front / passenger low beam malfunction" and I've been trying to figure this out for a while so I recommend checking the power to the ballast to make sure its not shorting.
Old 05-04-2013, 04:11 PM
Mein Auto: 330i E90
Follow-up on above
I got in my car an hour after I thought I solved this issue and the low beam would not turn on... So I checked the yellow and black wires again that power the ballast and they were not grounded against anything. I played with the end part of the harness that plugs in to the ballast and found out that's the issue. When I pushed the wires toward the ballast to make sure they were snug and checked my low beam it came on. I then pulled the harness plug away from the ballast (harness is still plugged in to ballast but just tug to loosen) and it would not come on. So I basically have a faulty harness that powers the ballast. So the wires are loose/unsecure that connect to the end piece that plugs in to the ballast. Somehow I'll have to find a way for the black and yellow wire harness to stay snug against the ballast. I don't think this is the type of thing that can be easily replaced because the yellow and black wires are part of the housing and basically permanent. They originate from the inner part of where the main harness connects and are only removable via the ballast side. They are part of the actual headlight housing.
Old 05-05-2013, 04:17 AM
Banned
would be nice to see a pic of the plug, usually they all have some type of snap connector, push in and a latch holds it in place
good thing is you found the short, now to figure out how to fix it
Old 05-05-2013, 11:27 AM
Mein Auto: 330i E90
The plug is a snap connector and two latches hold it in place. The wires going into the plug are not secure, it's not the actual plug/ballast connection.
Old 05-08-2013, 11:45 AM
E92-Lighting's Avatar
Mein Auto: 335i
Originally Posted by up2parr24 View Post
Fixed this issue!
, nicely done
BMW ACCESSORIES and PARTS
Old 05-08-2013, 11:55 AM
Mein Auto: 330i E90
Originally Posted by E92-Lighting View Post
, nicely done
Thanks. I wonder how many people with this issue have wasted money on new bulbs and ballasts when the fix is securing the power supply to the ballast. I mean, I have been researching this for a month or more and everyone says ballast/control module.
Old 06-29-2013, 11:43 AM
SFgiants1984 SFgiants1984 is offline
Mein Auto: 2007 330i
Great timing
Thanks for your descriptive posts up2parr. I just had the exact same thing happen to me and was expecting to replace ballast, etc. I will check out what you said today after work and post back later today or tomorrow. Did you ever figure out a permanent solution to keep the plug securely latched?
Old 06-29-2013, 12:42 PM
Mein Auto: 330i E90
Solution
1)buy a new headlight
2)have someone who is good with wiring (automotive electric or radio install) reinforce the wiring connection.
I used the 2nd option and it was done by removing the wheel and front fender liner. Headlight removal was unnecessary.
Old 04-17-2014, 12:13 AM
sean19761 sean19761 is offline
Mein Auto: 2008 528xi BMW
history:
I have a 06 330i e90 and the passenger low beam malfunction error is on my idrive along with the passenger low beam being out. The rest of the headlight works properly. Two months ago i had this issue, i replaced the ballas/control unit, the bulb, and the wire that connects those two. It fixed the issue after install, then next day it went out on startup and then came on in mid drive about 15 seconds later. After that its been good for a couple months until past two weeks. Past two weeks i noticed flickering and then it'd stay on. The last couple days, no flickering and it won't come on. So, i know my ballast is good, the bulb is good, and the headlight does function properly... Any ideas? Looking at the diagram part numb 63127189312 could be a possible issue but that looks like a electric module for the adaptive parts and not the actual low beam. Here's a link to see the diagram, its part numb 3: http://realoem.com/bmw/showparts.do?...63&fg=05&hl=14
any ideas? Thanks for reading.
James
normally if purchase ballas you can buy them as a pair. Did you change both sides. Secondly is bulb and ballas same watts. Your ballas maybe 35w and bulb is 55w, if so this maybe the issue or yet . Did you mistakenly touch the bulb with your hands. Always wear cloves. When handling bulbs light.
Old 04-17-2014, 05:53 AM
Mein Auto: '06 AW 330xi
This thread is from a year ago...
Old 11-11-2014, 05:50 PM
redwood78 redwood78 is offline
Mein Auto: e70 lci
Follow-up on above
Ok, this is EXACTLY my issue. 2006 330i, passenger side low beam and for certain the issue is that black and yellow wire connector. BMW wants $2k for a new headlight, even though I told them exactly what the problem is (black and yellow wire connector into the ballast). If I mess with it the low beam headlight will come back on and work for about a week, but then like it fails again. I cannot find a part number for black/yellow wire connector. Anyone??
Old 11-11-2014, 06:37 PM
Mein Auto: 330i E90
Take the headlight to someone who is good with wiring, I.e., car audio guy. The black and yellow wires need to be reinforced. There is no part for this. It's either a new headlight or you get the wiring re-secured by someone. That is what I did. No problems since.
Old 11-12-2014, 07:41 AM
Remove the connector and gently pry the interior pins inward. This will put more tension on the pins when installed and should solve your issue.
Old 11-12-2014, 08:01 AM
Mein Auto: 330i E90
He has already tried to push or pry the wires into the connector/plug and its a very temporary fix.
Old 11-12-2014, 08:07 AM
Mein Auto: 330i E90
I will repeat. Your only options:
•Get a new headlight
•Find car audio or indy mechanic who is good with electrical. Have them reinforce the wires into the connector/plug so both wires make a secure and consistent connection with the plug/connector -- the wires are loose within the plug. (This option is best done by lifting the car, removing the wheel and front wheel well. It's a lot less envasive than removing the headlight.
From experience, option two is the best and most cost effective.
Old 11-20-2014, 05:24 AM
Mein Auto: e70 lci
thanks for the replies. i really do not want to have to take the headlight out, but i guess it may come to that. for the time being i was able to wedge a piece of a rubber sink stopper that i cut to size, in between the yellow/black wire connector and the flat part of ballast housing. this effectively puts a little tension on the connection. I would have rather tried the fix of bending the pins a little, but I can't seem to get that connector to disconnect.
Old 11-20-2014, 07:08 AM
Mein Auto: 330i E90
You do not have to remove the headlight to fix this issue.
Old 01-17-2015, 06:42 AM
Mein Auto: e70 lci
no surprise, my rubber sink stopper fix did not hold. got me by for about 6 weeks though. just bought this on ebay. i'm wondering if maybe i can just replace the whole ballast with this, and splice it into my existing black / yellow wire.. without removing the headlight. thanks again for everyones help
Old 07-06-2015, 04:39 PM
be-em-veh-808 be-em-veh-808 is offline
Mein Auto: E91 328 Touring (SPP)
@redwood78 --- Reviving an old thread. Were you able to splice into the black/yellow wires? Did it work out? How did you finally resolve?
My 07 E91 Wagon is experiencing low beam light issues. I replaced bulb (w Osram/Sylvania D1S) once, it worked. Two days later it goes out.
I buy another Osram D1S. When I did the swap, the first replacement bulb looked OK. Nevertheless, I did the swap --- no light comes on.
I will attempt to wiggle the black/yellow wires that connects to the plug that inserts into the ballast and see if the light comes on. If not, then check the other end of the yellow/black wires to make sure it is secure to wherever it is connected to.
If still doesn't work, then I'll go the "replace the ballast route".
Old 07-06-2015, 06:42 PM
Mein Auto: e70 lci
by the end i became an expert at popping the headlight cover off and getting my finger in there to press the connector and get the light back on. however i could never get the black and yellow wire connector released from ballast so that i could just splice in the new (used) connector and connect it to see if the problem was the connector or the ballast. i got tired of dealing with it and a guy at a shop near where i used to work (who knew what he was doing) took the bumper off, took the headlight out, spliced in the new yellow and black wire and put in the new ballast for 2 hrs labor ($250). i was happy with that deal and its been fine since. so in summary, i really can't say whether it was the ballast or the black/yellow wire and connector that was the problem. i wanted them to keep the old part to inspect it but it just didn't happen. if i was doing it over again i would not screw around and would simply look for a good condition used ballast with that yellow/black wire attached for $100 or so, take the headlight out and put it in. Bmw tells me you can't buy that yellow/black wire with the connector as an individual item -- they tell me you need to buy a whole headlight to get it
Old 07-06-2015, 10:34 PM
Well, glad that you finally got it sorted out, even if you had to fork up a few bills to get it done.
So, I removed the wheel and wheel well panels and got into the low beam bulb again tonight. Third time in 4 days! I tried to trace the yellow/black wires away from the ballast connector to see where it ends. It seems like it traces back to a wire harness connector above --- I can see the connector when I open the hood, but not able to see the yellow/black wires going into it.
So, I tried to wiggle yel/blk pair in and out to see if the light will come on or flicker --- nothing. Tried pull the plug out of the ballast --- won't budge. I did observe that if I unbolted the ballast, there might be enough wire to lift the ballast up so that I can access from under the hood and remove the plug/clip/ Did you also observe that?
What do you mean when you said you became expert at popping the headlight cover off? Is that the black plastic cover that covers the entire light bulb buffet area? Or the spring loaded clip that holds the low beam?
When you press the connector do you mean the connector that attaches to the end of the yel/black wires? When I did that --- nothing happens. I did notice that the connector has a top/bottom halves that appear to be somewhat separating, thus not connecting to the wires snugly.
My next step is to buy the ballast and also the black cable (running from low beam bulb to the ballast --- $25 safe insurance). Do you think I will be able to remove the clip/plug after removing the bolts?
As for buying the clip/plug. This is the closest thing I found --- a wire harness kit for the lights (w Adaptive Headlights)... $245 via ECSTuning
http://www.ecstuning.com/Search/61119133642/ES161543/
Thanks again for replying.
Old 07-07-2015, 04:52 AM
Mein Auto: e70 lci
you can access the ballast where the yellow/black wire connects from the black access panel behind the headlight. it was to the point with me that in the dark i could pop the hood, remove that access panel, and get my finger in there to press that connector forward and back until the light came on. so give that a shot. in other words when the headlight goes out pull off the access panel that is innermost on the back of the headlight and try to press on that connector. try using a mechanics mirror if necessary to see it. access is better with pulling off the wheel and wheel arch, but it isn't necessary.
i could never figure a way to get the ballast out without removing the headlight, although other people on the internet have reported doing that. think it might be year specific. didn't seem possible on my 2006 330i. and finally yes is cost me $350 but keep in mind bmw wanted $3000+ to replace entire headlight, and i could have (and I think most people) could) diy the removal of the bumper and headlight if you have the time, which would have made the fix $100.
beam, e90, headlight, headlight malfunction, low, low beam
