E46 (1999 - 2006)
Old 05-03-2013, 06:58 AM
I-MAN I-MAN is offline
Mein Auto: 2002 BMW 325i
Speakers
I have a 2002 325i i bought it about 3 months ago and need to replace the speakers. what is a good brand and doses it have a factory amp for the speakers. I love my girl for a 2002 it drive and feels good everyone who's been in it say is a smooth ride.
Sent from my C5170 using Bimmer App
Old 05-03-2013, 08:21 AM
E46landshark's Avatar
E46landshark E46landshark is offline
Prowlin
Mein Auto: 2004 325ci
Punch PX-12 highs have been my best experience when i was in the audio game. If you run any kind of amp to them they'll get as loud as your ears can handle.
Old 05-03-2013, 01:59 PM
Thanx for the info.!!!!
Old 05-03-2013, 08:33 PM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
do you have the HK system? What speakers are you needing to replace? Whats wrong with them?
If youve got the HK system, you will have a little work to do, as the speakers in the doors and i believe in the rear deck are 3 Ohm resistance, and most amps today are 4, so you would have to replace the amp.. if you replaced the amp you might as well just replace all the speakers... i am having exactly this problem, replacing a couple speakers really just wont do it.
Rockford Fosgate makes great amps and pretty good speakers, but in "speaker world" you really get what you pay for, so dont expect much from a cheap 100 dollar set.. Their Punch and Power series are very widely known.. Polk is also not bad either.. not to mention, check out crutchfield.com , you can type in what car you drive and they tell you pretty much everything you need to know
any other questions, just post!
if you are crazy rich, Google Focal, their speakers are nuts.
Old 05-04-2013, 05:59 AM
3 of them are blown and want to replace them all but someone told me to check if the car has a factory amp that will limite my choice of speakers or change the system and i want to keep the original radio it has the BMW business want to keep the car original
Old 05-04-2013, 06:54 AM
bmw330ci04's Avatar
you will most likely have an amp if your car has the Harman Kardon logo on the tweeter speaker grille. However even if it doesnt you could still have an amp, or not..
to know for sure, remove the carpet covering the spare wheel for easier access, remove the trim peice to the left of the trunk (that black thing held in my two grommet like things), then there are a couple grommets holding the carpet on.
Take those off and you will (or will not) see a tiny little amp screwed into place behind those two storage compartments you have in the trunk if you dont have a cd player.. it shouldnt be hard to miss, its the thing with all the wires going to it.
If you want to keep the car original it will be a lot harder to do than just getting an aftermarket head unit, but it can be done, youll need a Line out converter in order to send RCAs to the amp from the headunit by tapping into some speaker wire. However, if you get a new amp you will have to buy speakers of the correct impedance (the 3 ohm OEM speakers most likely wont work) and install passive crossovers or for better quality install an active crossover (between the headunit and the amp) because i dont think the BMW headunit does the "crossing over", haha, i think the amp does.
and i agree with you, dont replace three, you might as well replace them all, but beware, look for a speaker on the shallower side for the doors because (in a coupe at least) there isnt a lot of room there.
Haha sorry for the long response, feel free to PM me with questions if you like!
Old 05-05-2013, 08:06 PM
Thanks that was the respond i was looking for!!
Old 05-06-2013, 08:28 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
The e46 wiki (link on this page above your first post) has a lengthy write-up on what your options are with Harmon Kardon system and probably good advice otherwise. Lots of good info in there otherwise too.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
