Old 05-03-2013, 10:56 AM
lookingtobuy447 lookingtobuy447 is offline
Mein Auto: z3
Looking to buy z3 oem sub
Like the title says Im looking to buy your oem z3 sub, non HK I will pay the shipping also. Please e-mail me at jjabolafia@yahoo.com
Old 05-03-2013, 01:31 PM
AustinZ3 AustinZ3 is offline
Teenage Speed Demon
Mein Auto: Z3 2.5i Roadster
Only the speaker or the enclosure also?
2001 Z3 2.5i, Spyder Halo Headlights, Kicker CompVT65 Subwoofer, LEDGlow Million Color Underglow Set
Old 05-03-2013, 02:34 PM
Mein Auto: z3
I only really need the sub, but if you want to sell it with the box that could work also
Old 05-03-2013, 05:34 PM
Teenage Speed Demon
I have both after replacing with a Kicker CompVT65, which is definently the route ide suggest, but if you are set on the oem sub we could probably work something out. But may i ask, why the oem?
Old 07-20-2013, 01:18 PM
grecken grecken is offline
Mein Auto: 2000 BMW Z3 2.3
Which impedance rating??? 1 or 2 ohm. I believe kicker discontinued the 4 ohm, which was recommended in another thread. Thanks!
Old 07-20-2013, 06:37 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
Their website does not show that the 4-ohm has been discontinued. That's the one you want.
http://www.kicker.com/CompVT
You should be able to find them anywhere.
Old 07-21-2013, 05:49 AM
The online sites where I've found the 4 ohm either say out of stock or discontinued. The Kicker website won't let me add either the 2 ohm or the 4 ohm to my basket. Could be my laptop. Here the ones at Cructhfield, either 1 ohm or 2.
http://www.crutchfield.com/g_520/Com...5%5d6-3%2f4%22
Old 07-21-2013, 06:15 AM
Looks like the Kicker 40CWRT672 can be wired in 2 ohm or 4. Its a dual voice coil.....will this work????
Old 07-21-2013, 08:44 AM
dkindig dkindig is offline
Mein Auto: '01 Z3 3.0i Roadster
This may work. Looks like the mounting depth is just under the depth for the CVT series (info says 2 3/4", CVT is 2 7/8"). Mounting hole diameter is the same at 5 9/16". The only area where I can see there might be problems is the 6 3/4" diameter instead of the 6 1/2".
The 6 1/2" CVT requires grinding away a portion of the rim so that it will fit the stock enclosure without compromising the integrity of the enclosure. If the overall diameter is larger than the CVT, or if the rim of the speaker is narrower in order to make a 6 3/4" cone, it might be difficult to grind away enough material to make it fit the enclosure.
The 2-ohm dual voice coil model will give you good flexibility. Some amps will drive a 2-ohm load if they're not bridged, and most bridged amps need a 4-ohm load. And yes, you can wire the coils in series to get a 4-ohm impedance for a single-channel amp or you can drive them independently with a two-channel amp that will accept a 2-ohm load.
