E46 (1999 - 2006)
Old 05-04-2013, 03:44 AM
Bligdon Bligdon is offline
Mein Auto: 318i e46 2002
Exclamation 2002 Bmw 318ci e46 cut out and no start
Hi,
A few weeks back my BMW randomly cut out whilst driving. I have a friend who's a mechanic and he plugged it in to get a cam sensor fault. This was replaced and the error codes wiped. As we tried to start the car again (with jump leads) it still fails to start up, there is some popping but no roar. Can anyone help here?
Old 05-04-2013, 07:36 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Originally Posted by Bligdon View Post
Hi,
Just a thought. Get your friend to check fuel pressure at the rail on the engine. When was fuel filter last changed? Fuel pumps last anywhere from 6-12 years, dying from time as much as miles.
Also, if it was not a genuine bmw sensor that may be the problem. Aftermarket rarely work out. Could also have just gotten a bad one but unlikely. It's probably something else that caused the cut out and the cam sensor was just close to dying and threw a code. Older cars, multi-failures.....
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
318, cam position sensors, cut out, start up problems
