E46 (1999 - 2006)
Old 05-04-2013, 04:49 AM
r0gue r0gue is offline
Mein Auto: na
Tire shop stripped one of my wheel studs. - Help!
I need some help. Two issues (unrelated). Rear wheel strippage, and front wheels seem unbalanceable. Bonus Issues included for your entertainment only.
Issue 1.
Obviously I'll replace the stud. Do you think I can tap the hub back out? or will I need to replace the hub? It's a 5 bolt patter BMW 325i. I was able to get it out (obviously), and even back in as I needed to drive the car. It went back in tightly of course. I think I'll be able to get it back out, and thought perhaps I could just get a finishing tap (somebody suggested that variety). Think I can clean it up with a tap? Someone tole me the hubs are hard and the studs are soft and thus the damage is probably all to the stud...?
Bonus issue - now resolved
and THIS is a different wheel. NOT stripped, just way bugger-over-torqued. I had a front end alignment done and as it still feels out of balance, I decided to pop the front wheels off to see if they lost the centering rings. They didn't..
Issue 2. - No Photo:
These friggen wheels wont balance. They were to come from Tire Rack pre-balanced. They had some hop (steering wheel shake). Took em in to be balanced at a local place. The problem was still there. Took em back. They monkeyed with them again. Problem is worse. Checked to see if the centering rings were lost (they were not). I dunno. I hate them and want to return them, but I'm sure that's a pipe dream. Tire Rack wants me to shuffle them around and look for one that may be out of round. Sounds like fun. Jack, swap, bolt, jack swap bolt. Sigh...
Post today and I'll even throw in another BONUS issue - NOT resolved
Junk ass Tire Rack wheel center cap stick-on logo flung off of rear wheel. I actually HAVE called Tire Rack about that. They said they are back ordered. They'll send me a set in a few weeks. Sigh...
Old 05-04-2013, 04:59 AM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
I had similar problems with several tire stores over torqueing my wheels. Suggest finding another place or insist that they use a manual torque wrench and not the air wrench.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 05-04-2013, 07:54 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
I always take off my silver valve caps as I didn't get one back one time, and retorque my wheels once I get home just to make sure it's torqued right. I give them the torque value and that seems to keep them from way over tightening, but the values always seem to be all over the place lug to lug until I true them.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-04-2013, 08:05 AM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
we too have recently had a bit of an issue with Tire Rack selling us there terrible house brand wheels.. After one season on the 335, one is cracked and dented inwards, and another one is dented inwards in two different places, and they will not do anything about it, and they said it was our fault, when we told them our 9 year old BMW rims had been through pretty much everything and back and that theyre still in good shape, they didnt seem to care..
I would try writing a letter to corporate HQ explaining your situation and disgust with the lack of help.
Old 05-04-2013, 09:57 AM
Mein Auto: na
I've spent my last dollar with Tire Rack. Two sets of wheels and at least a half dozen sets of tires. It's just not worth it when you have even just one problem and they leave it all in your bag to attend to it. IMO the should have sent a call tag and took em back. "Save the relationship" is the good call of the day to garner a good customer for life and avoid bad press online. They missed the boat.
Probably 200 miles on them and I'm stuck with them for good. Their rep was kind to me and is trying tohelp within the bounds of their normal policies. I just don't think this should be my problem to troubleshoot out and now I won't have a road force balance either.
Old 05-04-2013, 04:58 PM
Mein Auto: na
Anyone know what size tap I need?
Old 05-04-2013, 06:14 PM
cwsqbm's Avatar
cwsqbm cwsqbm is offline
I do'nt make mistakes.
Mein Auto: Quadricycle
The bolts are 12x1.5 (12mm diameter, 1.5mm pitch).
.................................................. ................................Garrison-Jenner 2016 .................................................. ..........................................
Old 05-04-2013, 06:15 PM
Mein Auto: na
Thank you! Much appreciated!
Old 05-04-2013, 08:19 PM
rav31 rav31 is offline
Mein Auto: 2001 540i/6 Tisilver/gray
You will need a new bearing hub to correct this correctly. What it appears to me is that the threads in the "Bearing Hub" where stripped out & not the threads on the lug bolt. You can not re-tap the HUB as you will need to go over size then the lug bolt wont work. The other option is putting in a Heli-coil but that's difficult to do with the hub on the car.
I hope that I have seen it wrong.
BMW CCA #132981 Tarheel Chapter,
Old 05-04-2013, 08:55 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
I think you see pretty clearly
Old 05-05-2013, 05:14 AM
Mein Auto: na
They quoted me $600 for a new hub at the dealership
Old 05-05-2013, 08:41 AM
ahull's Avatar
Ooofff! I'm sure you can get a better price at an indy, not to mention it is DIY-able - may have to buy some tools but shouldn't be much.
Old 05-05-2013, 08:51 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
You can DIY a new hub for sure. Dealer prices on parts and labor are insane. If you will replace it, do both fronts and you'll be good for a long time.
Another suggestion, if re-tapping doesn't work... heli-coil.
Jeff R.
Old 05-05-2013, 10:44 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Time-sert would be a better choice for this application....
http://www.youtube.com/watch?feature...&v=RvmL0pEphQI
The road goes ever onward....
(R.I.P. Jever)
Old 05-05-2013, 12:17 PM
jvr826's Avatar
Is it Trackday yet?
Nice!! Never heard of them before.
Jeff R.
Old 05-05-2013, 12:34 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
And why isn't the tire shop dealing with all this, instead of the OP? If they caused it, they should make it right.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 05-05-2013, 01:19 PM
evanwest94 evanwest94 is offline
Mein Auto: E39 540I
Tell the tire shop to deal with this!! Im 90% positive that they didn't thread that lugbolt by hand before they gunned it on. With euro cars they go on very easily without hand tightining but sometimes it doesn't work too well. I work at a tire shop and I've seen it happen first hand. Tell them to deal with it! It's not a good look for the shops image if you make a yelp about it too. By no means should you have to handle this on your own.
Sent from my HTC VLE_U using Bimmer App
