Old 05-04-2013, 07:45 AM
zach0726 zach0726 is offline
Mein Auto: 2010 335d, April build
Valentine Mount
Any recommendations for a Valentine radar detector mount? A buddy of mine bought a really slick one from EAS for his M5 (link below), but EAS' site says it does not fit our 335s....2010 diesel, in my case. Thanks!
http://www.europeanautosource.com/pr...detector-mount
2010 335d, April Build, Michelin PSS, Saddle, Nav, Premium, Winter
1998 Jaguar XK8
2003 Toyota 4Runner
Old 05-04-2013, 08:39 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Very nice indeed.
But....is it a bit clunky?
Go for elegance and built-in security. Install this!
Old 05-04-2013, 09:47 AM
Wow....that's slick
1998 Jaguar XK8
2003 Toyota 4Runner
Old 05-04-2013, 05:01 PM
blademan blademan is offline
Mein Auto: 335i, X5 4.8is, e46 328i
This seems interesting as well
BlendMount
Old 05-04-2013, 05:31 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
I've been using the suction cups, tucked up to the right of the mirror, since the car was new. Works fine, essentially unnoticeable outside the car.
Old 05-04-2013, 07:52 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
They look good and probably work well if the cops arent using laser.
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 05-04-2013, 10:37 PM
Nickh Nickh is offline
Mein Auto: Corvette, 740iL, 328i
$89 is a little Ridiculous for me.
Make the V1 really stand out to be stolen & blocks the a good portion of the view.
Been using suction cup mounts for over 10 yrs in many cars w/out any problems, so far.
Looks OK too...
Name:	2013-04-26 15.03.23.jpg
Old 05-05-2013, 06:57 PM
BlendMount
That looks pretty slick. Thanks! Anyone every have a problem with too much weight hanging from their mirror and it dropping? It is just glued to the windshield.....
1998 Jaguar XK8
2003 Toyota 4Runner
Old 05-05-2013, 07:02 PM
Looks OK too...
Attachment 374863
Nick, Is your power hard-wired? It kinda looks like it is.... That's what I'd like to do. And Valentine provided the wire-taps, etc. My suction cups seem to release about once a week though, and I'm worried about ripping out a hard-wire tap while the radar detector falls - or just just breaking the detector!
Have any secrets to making the suction cups work for 10 years? Would love to hear them.....
1998 Jaguar XK8
2003 Toyota 4Runner
Old 05-05-2013, 07:16 PM
captainaudio's Avatar
Worlds Foremost Authority
When you hardwire the V1 plug the end of the cable into an RJ11 coupler like the one pictured below and attach it to the top of the windshield with double sided foam tape.
Then use a short RJ11 cable to run from the coupler to the V1.
I have done this on several of my cars. If the suction cup mount comes loose the V1 will hang from the cable. If the connectors on the short cable break (the plastic locking tab on RJ11 cables are prone to snapping off) the cable is easily replaced.
The suction cups will hold better if the windshield is very clean and if you spray them with, or wipe on some glass cleaner.
The RJ11 parts are standard telephone connectors, work fine with the V1 and are readily available at Radio Shack and other stores.
An additional benefit is that when you remove the V1 from the car there is no wire left hanging as you can also remove the short cable. If you remove the suction cup mount and wipe off the round marks there will be no indication that there is a V1 in the car.
CA
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 05-05-2013, 09:56 PM
I have 2 V1's installed in 6 diff cars over the past 12 yrs.
Paid a local stereo shop $20 - 29 (plus a black 4 wire phone cord) to directly hard wire into the overhead light console. They wire it so that it comes on & shut off whenever I start/stop the car. Works great.
I order an extra set of suction cups years ago. They seem to last the 3 - 4 yrs each, or w/ change of car.
Of course, when I first called V1 company, they don't recommend this install medthod & wants you to buy their wiring kit.
But it works great so far...
Old 05-06-2013, 06:09 AM
CA: That's slick, and probably what I will do!
Nick: Thanks for the info!
1998 Jaguar XK8
2003 Toyota 4Runner
Old 05-06-2013, 10:01 AM
KAP8's Avatar
KAP8 KAP8 is offline
Mein Auto: Alpinweiss F32
I agree. I'm going with Cal's link. That is really cool. I live in Virginia. I can't have the V1 in view.
2015 435i ///M Sport | Alpine White | Coral Red | 19" | Auto | Cold Weather | Driver Assistance | Dynamic Handling | Lighting | Premium | Technology | M-Sport Brakes | Rear Sunshade | HK | Leather Dashboard | MPPK | MPE | Dinan Suspension | BMWCCA #409820
PCD: 10/31/2014
Old 05-06-2013, 04:10 PM
I lived in VA for 10+ years, and always had the following V1 setup.
  1. I have used the hardwired route into a switched outlet in the sunroof/light area. I've always used a black RJ11, but I like the RJ11 coupler suggestion from captainaudio.
  2. I've always used the suction cups to mount the V1 to the windshield. Saliva seems to make a good seal for years.
  3. Since I lived in VA, I used to mount the V1 directly behind the rear view mirror, but to the right so the rear facing radar and laser sensor can "see" rearwards
  4. To see the alerts, I've also always had a V1 concealed display mounted in or near my instrument binnacle, but accessible so I can mute audio.
Never had any tickets for this setup. And I actually got pulled over once in VA in an M3 cab, with the top down, no issues.
Now I did get 3 tickets for radar detector illegality, but that was with pre-V1 Escort/Passport and VG-2 sniffer a long long time ago, and been with V1 ever since. Once for doing 5 below speed limit in right lane, but I had the Passport windshield mounted with a coiled cord in a loaner. Loaners/rentals are a PITA, since I have no idea where my cig lighter unit is when I need it. But never for a speeding ticket.
My car buyers have always insisted I leave the complete V1 setup in place. When I get home, I'll post some pics.
Old 05-06-2013, 08:49 PM
I've attached another pic of V1 w/ phone cord direct wired to the light console.
Of all my cars, the V1 fits & looks best in the 3series, esp w/in the "notch" of the upper windshield.
Pic shows V1 from below view to show the cord, but at eye level, it fits in perfectly...
Name:	2013-05-06 15.22.17.jpg
Old 05-06-2013, 11:41 PM
  • left: binnacle from e46
  • right: e53 windshield mount and binnacle remote display
ID:	375190   Click image for larger version
Old 05-07-2013, 12:51 AM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
radar detectors are illegal here
interesting thread but I won't buy one
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 05-07-2013, 05:15 AM
KAP8's Avatar
Nice setup!
PCD: 10/31/2014
Old 05-07-2013, 04:31 PM
Now deciding for e90 whether to go with another V1 or Escort SmartRadar/Live, since mainly city/commute driving. Then again with Escort Live, I could run both a V1 and Escort Live on long hauls...
Old 05-07-2013, 06:12 PM
On my 335i the V1 remote is installed in the ash tray.
BMWCCA
Old 05-07-2013, 06:29 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
I followed CA's setup to the T when we hardwired the V1 in my E93. Nickh's photo is great for what it looks like from the inside the car perspective.
Here is what it looks like from the exterior looking in.
The biggest issue I've run into in the hot Texas sun with the RJ11 connector block is that the adhesive on the double sticky back velcro attaching the connector to the windshield takes a beating over the summer months. If you are willing to annually redo the adhesive (5-10 minutes of effort) the system is absolutely flawless.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 05-08-2013, 10:44 AM
E92-Lighting's Avatar
Mein Auto: 335i
i love my V1, i got three saves so far
BMW ACCESSORIES and PARTS
detector, mount, radar, valentine
