Still spewing some coolant... - Bimmerfest - BMW Forums
Old 05-04-2013, 04:31 PM
beamlord's Avatar
beamlord beamlord is offline
Wardaddy in retirement
Mein Auto: g11
Been almost 1000 miles after engine replacement. From very beginning I've been noticing some coolant being spewed out around the intercooler expansion tank.
To make it clear. This only happens when going really highrevs / redline and under load. I can drive around all day long and there will be no signs of it. Need to be pushing the engine for this to happen.
This is the part I'm talking about***********:
http://www.realoem.com/bmw/showparts...g=05&lang=enUS
It's definitely in the epicentre of the problem but I'm not sure if it's coming from the cap or from a crack in the expansion tank (the SA did a pressure test with over 1 bar pressure and there was no signs of coolant anywhere on the tank).
What I observe , is some coolant accumulated in this small "pit" marked red:
And some drops all over the engine. Here's schematically how the distribution of drops that I usually see , there's also quite a large coolant stain on the inside of the hood of course:
(not the actual engine)
So I'm sure it's not coolant overfill, especially since quite a bit of it has been already "flown" out.
Not sure if it's still a crack in the expansion tank - I don't know if ~ 1 bar pressure test is enough and how much pressure is developed during high revved engine operation (turbocharger operation) ???
The "picture" and the distribution of coolant DOES point to a crack in that "pit" spot as the most likely reason.
Or it's just the cap, which I'm also not sure if it's a pressure cap or just a regular cap that is NOT supposed to let any coolant out. The SA said it's a pressure cap but if you look at the part description in the realoem link above it says "02 Cover lid", and if you look at the main expansion tank cap here:
http://www.realoem.com/bmw/showparts...&fg=30&lang=en
It says "06 Radiator cap 2,0BAR"
which to me looks like it's the pressure cap and the other one isn't. So it could be the cap - although I can't see how the coolant can be distributed that way if it came from "under" the cap ...
p.s. now that I thought about it looking at the pics I made, it actually could - if you imagine the coolant flying out from the cap area initially forwards and at some point being blown off and backwards since a) the car if moving fast and b) radiator fan blowing it backwards, then the drops would indeed be appearing on the engine cover like that.
2016 G11 M-Sport Torque Monster, singapore grey, shadowline, ivory white / black, black alcantara.
Old 05-05-2013, 01:14 PM
beamlord's Avatar
Mein Auto: g11
Took a 150 mile drive last night on the autobahn with about 100 miles of it over 100mph and probably 50-60 miles constantly on the limiter, accelerating, stretching the muscles, really pushed the engine. The car runs like a on steroids and the limiter is a joke since there's what it feels like room to go up to 200mph.
Anyway, back in the garage, sure enough, there's a wet spot on the inside of the hood, and some coolant drops as described above.
Now, I noted the coolant level the day before that (in the MAIN expansion tank), and it was a bit over "min".
So after the mentioned run, I let the car cool off during the night and this morning checked the coolant level, it was exactly at the "min" level. I topped up probably like 2-3 ounces of water to have the level reach well above "min".
So to me, it looks like the amount spewed out is pretty miniscule - like, after over 2 hours track-like driving on the autobahn, it lost 2-3 ounces of coolant? I mean, it's not the end of the world - maybe it's even "normal" for this car (duh).
Any ideas on what I may be missing?
Old 05-05-2013, 02:01 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
You sure there isn't a hose leak?
2011 750i
Old 05-05-2013, 02:15 PM
beamlord's Avatar
Mein Auto: g11
Not sure about anything in this situation, but the hose (I assume you mean the one attached to the expansion tank on the left side) is dry, it does get some of the coolant drops but they're coming from elsewhere.
Old 05-05-2013, 06:17 PM
Wolfman64 Wolfman64 is offline
Mein Auto: 750li, S550, SL550, ML350
Being it back and have BMW figure it out. This is not normal behavior.
And for the speed limiter I think that one is easily removed via coding
Old 05-06-2013, 01:07 AM
beamlord's Avatar
Mein Auto: g11
Sometimes I think I'm nitpicking but you're right I also think this is not normal! Even if the effect is minimal and only occurs during high-performance operation of the engine.
Old 07-01-2013, 02:25 PM
ml99 ml99 is offline
Mein Auto: 750i F01
Maybe you already found the answer but I had the same problem and it took my BMW-dealer a while to find out.
One (of 3 I Think) of the lids could only handle 1,2 bar when it should handle 1,5 bar. It was not detected when they did the preasuretest.
Old 07-02-2013, 03:37 AM
jgriffith007's Avatar
jgriffith007 jgriffith007 is online now
Mein Auto: 2009 750 Li
Not sure how I am the first to post on this but 50-60 miles on the limiter?! Makes me smile from ear to ear to read that. I have only had mine up to 140mph. At the end of the run, I was clocked doing 95 in a 70mph. Was nice to the cop and ticket was for 80. Love driving this car fast, so much fun and so stable!
Old 07-10-2013, 11:13 AM
Mein Auto: 750i F01
This did not solve the problem... :-( If anyone has a better suggestion, please let me know.
Old 09-16-2013, 02:01 AM
Mein Auto: 750i F01
Finally they have found out what was wrong (I hope)! Some of the 750;s (mine included) had their engines replaced. When reconnecting the cooling hoses they connected two of them the wrong way! It has happened in some other cases in the world according to PUMA.
This build up a high pressure and you canít see from where the coolant is coming.
Now they have reconnected the hoses and I really hope this will make it stop spraying coolant over the engine.
So if you had your engine replace make sure that the cooling system is correctly reconnected. The mistake was difficult to locate since it is hard to see that it was incorrectly connected, the engine runs normal and it is only when you push the engine hard that the coolant leaks.
Old 09-17-2013, 04:22 AM
beamlord's Avatar
Mein Auto: g11
Waiting for the pics from you. Very excited! Can you also ask your SA about the reference number of that PUMA case?
Old 09-17-2013, 04:29 AM
Mein Auto: 750i F01
I was a bit surprised that the problem was located there because of the spray pattern (same as on your Picture) but in fact they were connected the wrong way. And as the garage said; They just assumed that the engine and the cooling system was correctly connected and that was why they had a hard time finding the problem. They also said it looked more correct when it was incorrectly connected! :-)
Hope this can help you.
Old 09-17-2013, 05:07 AM
beamlord's Avatar
Mein Auto: g11
Attachment 397331
Attachment 397332
Attachment 397333
Attachment 397334
Wow. This is indeed a bit off of the locations I'd look at when looking for the cause of that problem.
so to get this straight: the pics show the CORRECT connection now; and incorrect was that these two hoses were swapped ??
How much work was it and what did they charge?
Old 09-17-2013, 07:39 AM
Mein Auto: 750i F01
The pictures shows the correct connection and yes they were swapped before. I asked BMW if there is any case number but they say there isnt one.
Since I had a guarantee I didnt pay anything but they said it was an easy fix that wouldnt take long.
Old 09-17-2013, 02:08 PM
beamlord's Avatar
Mein Auto: g11
Gotcha, please keep us posted and do some high-rev high speed runs to check if the issue is really gone.
I will be scheduling a service appointment @ my dealer. No idea why I asked how much they charged, since mine should be also done under warranty anyway
Old 09-24-2013, 03:11 AM
Mein Auto: 750i F01
After a week now and a few high speed runs and reving it really seems like the problem is solved!
Hope you also found the solution to your problem.
Old 09-24-2013, 03:15 AM
beamlord's Avatar
Mein Auto: g11
Thanks a lot for the update, I am definitely going to visit my dealer
Old 10-23-2013, 01:28 AM
beamlord's Avatar
Mein Auto: g11
Finally found time to drop by the dealer, the SA was VERY surprised and wanted to take a closer look, then after a moment of embarassement he went "please leave the car here right now we want to get this fixed asap" ..
So they swapped the hoses.
I'm a happy camper now.
God bless you, if it wasn't for your report I'd probably never find out what's wrong !
Old 10-23-2013, 02:36 AM
Mein Auto: 750i F01
GREAT!
I am really glad I could help you. My car has been ok since they swapped the hoses.
My SA said they only found one (1) more incident like this one in Puma in the world! So now I guess there are three!
I guess there could be a few more cases since most drivers might not notice it if they donít rev the engine enough. The previous owner of my car didnít notice it and the dealer that sold it didnít find the mistake.
Old 10-23-2013, 09:26 AM
Snorlax Snorlax is offline
Mein Auto: _
Nice! Finally got this issue solved. Strong work!
Old 10-23-2013, 09:46 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
Seeing a German SA being embarassed - priceless!
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
