Failed to sign FDL & other problems - Bimmerfest - BMW Forums
Old 05-04-2013, 07:16 PM
mde83 mde83 is offline
Mein Auto: 2016 X3 35i
Trying to code my 2013 535i, build date March 2013. I am using the latest version of Esys and PSdZData 49.1...
Got all the software installed, purchased token from AKiss. Token came as a name other than the "code away.est". For the sake a this, lets say it was called "jejejeje.est". I did not change the name when I saved it to the Esys Est folder. And in the Esys program, I pointed the correct file "jejejeje.est" on the EST tab (Developer Soft Token EST path).
Car and computer connect fine. I am able to get my FA and read the VCM just fine.
First problem, is when I change a parameter in a CAFD. When I go to save I get an error message "Failed to sign FDL". So my changes are not being saved. Does this have anything to do with me not remaming the EST file?
Second problem, is I cannot find the HU_CIC module anywhere. I have an HU2 and HU_ERM or something like that, but no HU_CIC. I do have the remainder of the modules listed on the F10 cheat sheet. But several of the items I want to modify are in HU_CIC... Does this mean that I need a newer version of PsdzData? If so which version and which file? and where is the link?
Can someone please assist me with these issues? Thanks
2016 X3 XDrive35i, Alpine White, Saddle Brown, Premium, Technology and Driver Assistance packages (Took Delivery 1/29/2016)
2013 535i, Alpine White, Cinnamon, MSport, Premium, Technology and Driver Assistance packages (retired - Lease turn-in 1/29/2016)
Old 05-04-2013, 09:43 PM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
Did you install the 2 patched jar files which should have been supplied with the token?
You have to rename then before replacing the old ones.
You shouldn't have to rename your token as long as you configured it in E-Sys.
Old 05-05-2013, 03:22 AM
No I did not come to think of it. So I have copied them to the folder specified in the readme file. Question though. Do I leave the file names as they are? Est-cm-01.03.02-PATCHED... Or do I rename it to get rid of PATCHED?
Also in the target folder I did not have the other jar file. Psdz-core-PATCHED. Or anything like that. So for that one I am not replacing anything, just adding it to the folder right? And do I rename it to get rid of PATCHED?
Thanks!!
I don't suppose this will also fix my issue regarding seeing the HU_CIC module?
Old 05-05-2013, 05:10 AM
akiss akiss is offline
Mein Auto: 2016 MINI F54 Cooper S
Thanks!!
You have to remove "-PATCHED" on both files and there is a file in one subdirectory (e.g. C:\EC-APPS\ESG\E-Sys322\lib\PsdZ, named Psdz-core.jar where the second file should be copied (and renamed). The original files can be removed or renamed for backup (must not end .JAR).
A.
Old 05-06-2013, 09:36 AM
Thank you!!! I will get that problem fixed ASAP...
Old 05-19-2013, 09:58 AM
davidinNJ davidinNJ is offline
Mein Auto: 335ix
i have the same problem
Where do I get the patch from?
Old 05-19-2013, 10:04 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
PM sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 12-16-2013, 12:47 PM
as joker as joker is offline
Mein Auto: 118da
shawn,
Old 12-16-2013, 12:54 PM
Originally Posted by as joker View Post
shawn,
PM sent.
Old 01-01-2014, 12:12 AM
tareqwalid tareqwalid is offline
Mein Auto: 650i
patch files
Happy New Year!
May I also get the patch files please?
Many thanks in advance.
Old 01-01-2014, 01:52 PM
Originally Posted by tareqwalid View Post
Happy New Year!
I am not supplying actual patches. I can only refer you to a source.
PM sent.
Old 06-02-2014, 11:11 AM
yusuke1192 yusuke1192 is offline
Mein Auto: F20
I want psdz-core.jar
Old 06-02-2014, 11:16 AM
Included with your E-Sys / PSdZData was "E-Sys - Installation Instructions - v.5.pdf".
It explains how to obtain a Token solution.
And there is no need to post the same thing twice in different threads:
http://www.bimmerfest.com/forums/sho...postcount=2806
