The X5 SAV Forum
Old 05-05-2013, 06:07 PM
javed13 javed13 is offline
Mein Auto: 2002 bmw x5 4.4
AC Cold for 20 minutes then then becomes warm
Hi guys, my ac is cold for 20 minutes and then becomes warm. if i shut off the ac and turn it back on after couple minutes, it becomes cold. what could be the problem?
Old 05-05-2013, 06:57 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
When it is warm check to see if the compressor is running. Could be that you have a blockage in the system and the pressure is building up that the high side pressure cutout is kicking in, or the lowside is low and the lowside pressure cutout is kicking in. The only way to determine the problem is to connect a set of gauges to the system and find out what the pressure readings are.
Old 05-06-2013, 03:13 AM
flyace20 flyace20 is offline
Yippikayaaaay
Mein Auto: 2002 X5 4.4
I read a post on this forum about driving the car on open road and the system freezing up and not cooling.
Go to this thread, maybe you have the same problem. http://www.bimmerfest.com/forums/sho...d.php?t=463910
'02 BMW X5 LOVE THAT CAR
Old 05-06-2013, 04:09 AM
thehinch thehinch is offline
Mein Auto: 2003 E53 X5
Air conditioning control module located under the dashboard
Old 05-10-2013, 10:16 AM
BMWReeFeR BMWReeFeR is offline
Mein Auto: E53 X5
Ever figure this one out ace?
Old 05-11-2013, 06:01 AM
Yippikayaaaay
Next time it happens to me on the freeway I will test the theory by shutting off the Ac and allowing it to defrost. Then turn back on again in a few minutes, if it blows cold after this then it may well be that its true, the line is freezing up somewhere.
Old 06-09-2014, 07:56 PM
SC-Caniac SC-Caniac is offline
Mein Auto: 2013 550i M Sport
This is exactly what happens to my X5 50. Crank the fan on high and it sounds like its blowing really hard but no air (or very little) is coming out of the dash vents. The air is warm and humid. Turn it off for 15-20 minutes and it'll thaw out and work fine.....until it freezes up again.
Old 06-09-2014, 08:10 PM
Sounds like you are low on refrigerant.
Old 06-13-2014, 10:07 AM
Kwalk Kwalk is offline
Girl X
Mein Auto: BMW X5 4.4
Has anyone found a fix to this? I have 03 x5 4.4i and am having the same problem. Air blows great highway, but after a while the front vents stop, but back still works just fine. No matter how I adjust the settings it will not come back on. After I get out for a few minutes when I start the car back up, it works again. What could it be?
Old 06-13-2014, 12:55 PM
See the guy reply #8 just above your post #9
Old 06-13-2014, 05:18 PM
Girl X
Old 06-20-2014, 06:30 AM
Originally Posted by Kwalk View Post
You're welcome!!!
