Old 05-05-2013, 05:39 PM
Carter650i Carter650i is offline
Mein Auto: 650i
M6 Bumper Do or Don't
I'm thinking on pulling the trigger on doing the m6 bumper front and back using OEM parts. So my questions are is it really worth it? What should I be aware of? Would my headlight and FOG fit perfectly? Do I need new upper and lower grilles? Or I can use my old one? Must importantly do I need to do the 4 pipe exhaust like on the M? Thanks or I'm panning on doing the install my self and DIY is welcome.
Old 05-05-2013, 06:11 PM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
First, the M6 does not have fog lights, so the common solution is to tie up the fogs behind the bumper. I am not sure if the lower grills would fit so don't have an answer there.
For the rear the lights in bumper itself are in a different spot and the exhaust holes don't match up to the 6. For the lights you will have to do some modification to the carrier that holds the lights because of the change in position. Your body shop should be able to handle that (if you are using a shop?).
I would think the location of the 6 tips would be OK with the M6 bumper, but since it is designed for quad tips I think you will be disappointed with the look if you don't get the quad tips.
Old 05-05-2013, 06:14 PM
Mein Auto: 650i
You always helpful, thank you sir.
Old 05-06-2013, 04:26 PM
Mattman645 Mattman645 is offline
Mein Auto: 645ci cabriolet
I wouldn't bother myself - a lot of hassle for not a lot if gain - i actually prefer the stock look as the rear lights sit too high in the m6 bumper in my opinion, would spend the cash on a good performance exhaust with different tips if you want the car to look different
Old 05-08-2013, 01:10 PM
Ellicit's Avatar
Ellicit Ellicit is offline
Mein Auto: 528i
If you do some finding, you can pick up an M6 OEM used bumpers and some dual megnaflow exhaust which should run you about $1800/with paint/installed
Old 05-08-2013, 05:03 PM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
Lower grills are different and no fogs. The rear carrier is different. The front bumper is easy to remove/install, but you will need the air dams.
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 05-09-2013, 10:22 AM
Regmatc's Avatar
Regmatc Regmatc is offline
Mein Auto: 05' 645
Re: M6 Bumper Do or Don't
I did the front M6 bumber and love it. Just bolted on. My shop did it.Click image for larger version
Sent from my SPH-L710 using BimmerApp mobile app
Regmatc
Old 05-09-2013, 10:24 AM
Regmatc's Avatar
Mein Auto: 05' 645
Regmatc
Old 08-11-2013, 02:50 PM
Mein Auto: 650i
Originally Posted by Regmatc View Post
Attachment 375614
This thing is a beauty sir.
Old 08-15-2013, 07:20 PM
bigscore bigscore is offline
Mein Auto: 06 650i
Scroll to the bottom of this post (link below) for pic of M6 bumper fitted with fogs
http://www.bimmerfest.com/forums/sho...729&highlight=
No car is quite like a BMW....
