Old 05-05-2013, 07:27 PM
bimshaz bimshaz is offline
Mein Auto: 2009 BMW 335I Sedan
screeching sound while accelerating from zero
My BMW, 2009 335i sedan, is currently at 40k+ miles and its tires were never changed. Tomorrow I am taking it to the dealership for a regular servicing as I got a call from them saying it needs service.
When I accelerate from zero to like 25mph, I hear a screeching sound in the right front wheel. I can't hear it at more than 30mph. It started recently and I feel its kind of increasing day by day. Another thing is there is no sound when I start driving after the car has rested for a long while, say in the morning. As soon as I drive like 5-10 miles, stop at a signal light and go, it starts. I can also hear it when taking a left turn but not a right turn. Last time when I took it for service, I told them the same but it was not as regular as it is now. They said its nothing. This time I want to make sure they fix it. Could anyone please tell me what could be causing this based on my car's condition I mentioned above. I can provide more details if that helps Thank you!
Old 05-05-2013, 08:27 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
I would go drive it until the noise starts and then immediately come back home and jack up that right front and spin it by hand. You might have a bearing going out. Bearing noises have a resonance point (or speed i mean) and above that the noise and vibration subside. Not that this is the problem absolutely but one possibility.
Old 05-05-2013, 09:44 PM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
I used to hear a screeching sound when I accelerate too. I solved the problem by telling my girlfriend that she can't ride in my car anymore.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Old 05-05-2013, 10:12 PM
Roleez Roleez is offline
E60 to E90 to E92
Mein Auto: 2011 E92 335i M-Sport 6MT
If it's a screech sound, inspect your rotor. If there's a nice groove dug into the rotor, your brake pad is toast, indicating that the metallic warning tab on the pad is now contacting the rotor, hence the screech sound. Expect a rotor and brake pad job ... for both sides. What does your current mileage countdown on the OBD computer say? If the rotor is indeed grooved and OBD says you still have sufficient mileage remaining for front brakes, perhaps a faulty brake pad sensor is to blame (or incorrect mileage calibration). OTOH, if it was a bearing, you'd get more of a groaning resonance vs. a (metallic) screech. Again for both sides, expect front bearing removal and replacement if this was the scenario.
2011 BMW E92 335i 6MT (Space Gray/Coral):
Premium / M-Sport / CA / PDC / Navi / Rear Shade / Rear Fogs / HK Logic7 / InvisiGuard Film / Dinan Exhaust & Pedals
2006 BMW E90 330i 6MT (Sparkling Graphite/Terra): retired
2008 BMW E60 Dinan M5 SMG (Indianapolis Red/Black): retired
2006 BMW E60 Dinan 550i 6MT (Titanium Grey/Auburn): retired
Old 05-05-2013, 11:10 PM
BB Cuda: Ok I will ask the dealer to check that. Somehow I feel that it has something to do with the hotness of something associated with the tires. I mean, I observed that when they are cold I don't hear any noise. But once I drive for some distance, it starts. The longer I drive(the hotter that 'thing' gets) the more audible and longer the screech is.
Old 05-05-2013, 11:12 PM
Old 05-05-2013, 11:15 PM
Forgive my ignorance, but rotor is the shiny disc like thing that I could see through the tire's rims right? I just went out and checked but there is no groove on them yet. I don't know how to check the mileage count down you said. I just did the 'check control' and it says 'check ok'. Yes, its a metallic screech.
Old 05-05-2013, 11:17 PM
Can i ask the dealer to do the checks that I want as part of servicing? Like inspecting brake pads, rotors, bearing, brake sensors etc? I mean can he do it other than this standard check up that they do?
Old 05-05-2013, 11:20 PM
Also now that the car is at 43k+, is there anything specific that needs to be replaced/replenished other than tires?
Old 05-06-2013, 06:09 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Screech from the right front, only on acceleration, goes away warm, worse on a left turn, 43K?
1. Wheel bearing
2. (Are you ready for this?) Serpentine belt defect or bad pulley bearing, or
3. Brake problem.
The bill for my diagnostics is nothing, it's worth every penny.
Old 05-06-2013, 07:40 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
BMWs do not use a telltale tang on the brake pads to signal when they are worn out. There is an electronic sensor on the inboard front left and inboard right rear pads. When either of those two pads wears to minimum, the sensor contacts the brake rotor and trips a warning light on the dash. If you ignore the warning and burn through the remaining pad material, there is no additional warning--just the horrific scraping and grinding (not a screech) of the pad backing plate destroying the rotor.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 05-06-2013, 08:22 AM
E60 to E90 to E92
Never knew that! Appreciate the info!
accelerating, noise, screeching, squealing, tires
