The X5 SAV Forum
Old 05-06-2013, 05:05 AM
fadisarkis fadisarkis is offline
Send a message via ICQ to fadisarkis
Mein Auto: X5
ac problem
hi
x5 2004 3.0
my ac took more than 5 min after starting to blow cold air
what is this problem any idea
thx
Old 05-06-2013, 06:40 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Could be low on refrigerant, what has been done to the system? Is the condenser fan running when the ac is on?
Old 05-06-2013, 07:21 AM
Mein Auto: X5
i noticed that the electric fan in front of radiator didn't work is it the problem??
Old 05-06-2013, 08:40 AM
The fan is suppose to be running when the ac is on so that the refrigerant in the condenser can be cooled. If the fan doesn't come on at all I would check the fuse (It's located behind the glove box and it's a pretty large fuse 50 amps). If the fuse is blown chances are the fan is no good. A new fan at the dealers is somewhere between $500 to $1500 (depending on how much the dealer is a stealer) and about 4 hours to replace (the front bumper cover and metal bumper have to be removed).
Old 06-11-2013, 09:34 AM
Mein Auto: X5
I changed the fan but ac still taking 4 to 5 minutes before begin to cool what is the problen thx
Old 06-11-2013, 10:27 AM
Did you replace the 50 amp fuse after you replaced the fan? If the fan was Bad, chances are that it blew the fuse. The fan should be running when the ac compressor is on.
Old 06-11-2013, 10:50 AM
Mein Auto: X5
It is runing but the compressor took 4 to 5 min before blowing cold air
Old 06-11-2013, 03:20 PM
Do you know what the high side and low side pressures are when the ac is running and the ambient temp when these values were recorded?
Do you have the Automatic climate control or the manual climate control?
Old 06-11-2013, 09:52 PM
Mein Auto: X5
I have the automatic climate control
