Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 05-06-2013, 08:41 AM
Finnsane Finnsane is offline
Mein Auto: 2011 x3 3.5i
Unhappy Electrical gremlins in my new X3
I just purchased a 2011 X3 with less then 17,000 miles.
The thing is beautiful and with the dynamic sport package it drives like a dream.
I took her out on a 500 mile round trip for work and found some gremlins in my electrical system.
While driving at freeway speeds I received a notice that the cruise control had failed. It knocked me out of cruise control and I could not turn it back on with the steering wheel buttons. I then noticed that I no longer can any buttons working on the steering wheel. I also had no power in the left signal indicator and my business computer button would not change indicators in the instrument cluster. At the same time my air conditioning stopped working.
It has happened several times since my trip last week. Anyone out there experienced this before? I'm scheduling a service this week at the dealer under warranty but would sure like to know if anyone else has had similar problems.
Thanks,
F
Old 05-06-2013, 08:59 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
I assume you bought the car used, did you check the maintenace history of car before you bought it, it could have been a reoccuring problem. If not, I would ask your dealer nicely to show you the maintence history of your car.
Old 05-06-2013, 09:35 AM
TN_SUP TN_SUP is offline
Mein Auto: 2011 X3 28
The dealer told me there are about 30 computers in the 2011 X3. My turn signals wouldn't cancel and they found a fault in a computer and had to replace it. Got the latest software too, car drives much better. I'd bet they need to replace a computer or two...
Old 05-06-2013, 09:50 AM
Smile Records look good
Thanks or the replys.
The history looks good. I figured it was a CPU error.
I'll update once I'm out of service.
I'll post pics too!
finnsane
Old 05-13-2013, 09:02 AM
SpaceManGray SpaceManGray is offline
Mein Auto: 2011 X3 35i
Most of the controls in your vehicle, including those on the steering wheel, send signals on a data bus to the various computers (ECUs - electronic control units) in your vehicle. These computers also send data on the bus to communicate with each other.
Since it sounds like you're having problems with MANY of these control units, my guess is the data on the bus is corrupt. I would guess the problem is one of the following:
1. A loose connection on the bus is causing one ECU to communicate incorrectly and interfere with other ECU communication
2. One ECU is bad and is sending bad data, causing problems with other ECUs
3. There is a source of interference affecting the data bus
2011 X3 (F25) xDrive 35i 3.0L, nav, xm
Old 05-13-2013, 11:17 AM
Drewsky's Avatar
Drewsky Drewsky is offline
Mein Auto: '14 X3 35i-M Space Grey
Thanks,
F
Back in my days of my e46, this exact situation was caused by the flexi cable between the (rotating) steering wheel and the (fixed) steering column. First the buttons on the wheel either quit entirely or act wonky, then blinkers (and/or wipers) quit, and eventually you will get an SRS light on the instrument cluster. Seems when that starts going bad it interferes with the data bus as others above have mentioned. My money is on that little flexi cable.
Old 05-15-2013, 08:13 PM
I should have it back from the dealer tomorrow and will fill you in.
They are reprogramming it, also a software upgrade.
Old 05-19-2013, 01:11 PM
Got my X3 back on Wednesday
I picked up my X3 from the dealer on Wednesday.
Needed the JPE central control unit replaced.
Dealer completed the following.
Replaced central control unit JBE replaced / vehicle reprogrammed.
Front door lock passenger side replaced. Was sitting about 1/2" higher then the rest of the lock indicators.
All new wipers.
New software upgrade (thanks to the board for providing the insight on turbo lag)
Full vehicle inspection.
All work completed under warranty.
Car electronics seem to be working correctly now.
My Vehicle Specs:
2011 X3 3.5i F25
16,000 miles
CPO
Space Grey Metallic
Black Nevada Leather interior with brushed aluminum trim
Sport Seats
Sport Activity Package
Premium Package
Heated Steering Wheel
Heated Front Seats
Professional Navigation
Smart Phone Integration
BMW Cross Rails
Some reflections as I approach 1 month of ownership.
The new X3 is beautiful. I love to look at it. The combination of Space Grey with the X line trim and silver roof rails is sharp.
The drive is incredible, very connected to the road and the 300hp twin turbo is quite a thrill to experience. I love getting on the freeway and opening up the motor.
I prefer to drive it in Sport Mode with only the chassis tuning active. I use the steptronic shifter to control the revs. The 8 gears take some getting used to as i explore the correct gearing when accelerating and slowing.
The Bluetooth integration is great for accessing my music collection. I love the programmable buttons, i have Bluetooth audio as a button and can call up the music player just as you would a radio stations. I don't mind the IDrive, i have learned how to access everything.
I wish they were offering the 6 speed manual. I traded in a 2005 X3 6 speed for this vehicle and I miss shifting. I see the export models with a 6 speed online and drool over them.
That is the only thing I would change on this vehicle.
Overall the experience of owning this car is a thrill and I look forward to driving it everyday.
Some customizing I'm contemplating:
De-badging
Changing the emblems to be the red propeller
Window Tint
Thule Cargo Box
2011 2012 x3, air conditioning, electrical failure, x3
