Old 05-06-2013, 02:44 PM
Banned
Mein Auto: 2007-335 HTC
Zenon lights and dash light comes on 2007 335i
I have zenon lamps, and I was trying to get the inboard lamps to come on with the parking lamps, kind of like having running lamps, so took off the plastic lamp cover, and found an empty 12V source, where all the wires come from, when the light switch is in the 1 position, hooked up a jumper and YES the lamp comes on, but now I got a warning light on the dash, No problem just reset it, well I did and now the car on lift comes on in red. Service soon now lights up. tried to reset is and it wont let me
what to do now?
Yes I figured when I hooked up that guessing H8 bulb it threw a code
I hate it when a car is smarter than I am
Hondo
Old 05-06-2013, 04:58 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Revenge....the very next thing in AI
Old 05-06-2013, 05:39 PM
Banned
well now the BRAKE light stays on in RED, got to see if that means the brake pads need replacing, coincidence or payback
BMW, you dont have to read our mind "we at least give you a clue what's wrong
yea I will catch Hell from the ladies on here
Old 05-06-2013, 07:50 PM
twhisten twhisten is offline
Drive it like u stole it!
Mein Auto: 2016 M3
Take thecjumper off then reset it
1997 328i- retired
2007 328i- retired- lease
2006 330xi- retired
2011 335xi-PCD-12/13/10 - DINAN3-----retired
2013 M3-Laguna Seca-6 speed-EDC ------retired
2016 M3
2006 X5- retired
2011 X5- retired- buy back
bmw cca#443379
Old 05-07-2013, 03:05 AM
Banned
I did take the jumper off the light, tried to reset it, still wont reset, I get to the Car on lift sign, the RESET light is on and a Check is showing, but it wont Reset,
I visually checked the brake pads thru the wheel spokes and it looks like I have at min a 1/4 inch of pad left
any suggestions besides me pulling the wheels and pulling the pads out
Old 05-07-2013, 05:11 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Take it a to a shop, get it hooked up to a diagnostic computer and find out whether you fried any of the lighting-related control modules. DIY if you have the necessary equipment. It's worth double-checking the monitored pads--inboard front left, inboard rear right--just to be sure but this doesn't sound like a coincidence. The sensor trips at 2mm pad thickness IIRC. You don't need to remove the pads unless they appear to be worn close to that limit, just remove the wheel and check through the inspection port in the caliper.
These cars use embedded systems to control a lot of things that used to be handled by simple switches and relays. They can react very badly when you connect power or additional loads in unexpected places. If you are lucky, the module that controls lighting functions (footwell module? maybe others) was merely confused by your experiment and needs to be reset directly through the diagnostic bus. If you're unlucky, you're looking at a few hundred bucks for a new module somewhere.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 05-07-2013, 05:30 AM
Banned
well thats probably what I have to do, No more experimenting on this car
Old 05-07-2013, 07:55 AM
Banned
Well at the BMW place. They checked it out. And some one replaced the rear brake pads and left the sensor off. So they are replacing
The sensors. They are also doing the battery cable recall
Old 05-07-2013, 09:10 AM
Zeichen311's Avatar
Nice.
It's interesting that this seemed to coincide with your headlight experiment. Usually those sensors alert right away, or the system won't reset if the sensor is missing/tripped (they are one-time-use--the sensor trips when the rotor abrades away the tip). That's probably why you couldn't reset it the second time, but it's odd that you were able to drive around without a sensor with no warning until then. Coincidence after all--you lucked out!
Old 05-07-2013, 10:31 AM
Banned
Yes that is strange to me too. Especially since I took the Car to the same BMW Dealer back in OCT because the Aux input didnt work and it wouldnt recogonize the SAT radio, and they recoded the radio unit and cleared all the codes, you would have thought as smart as their computers are they would have picked it up then. Kind of makes me question the guys working on my car
