Old 05-06-2013, 05:01 PM
Romanianbimmer Romanianbimmer is offline
Mein Auto: 2010 335xi
2010 335xi not charging help!!!
Hello everybody I have a 335i xdrive and it is giving me problems. Sometimes she runs fine. But it lately hasn't wanted to start with out a jump. And now it is showing charging system malfunction. But it does not do it all the time now it doesn't want to charge at all the car just faded out and died. I do not know what it could be. Please help!!
Old 05-06-2013, 05:10 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
It's the alternator or the battery.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 05-06-2013, 08:08 PM
I had the alternator checked and they said it was pushing 14.4 amperes. But the alternator was still on the car and still could not make it sure.
Old 05-07-2013, 05:12 AM
So if it's not the alternator, then it must be ______?
A. The battery.
B. Demons inside the car.
C. The battery.
D. The battery.
Frederic
Old 05-07-2013, 07:42 AM
But isn't there a sensor in the car that controls the voltage to the battery? It started happening after I put tried to charge the battery from the front mounts and the charger did not show voltage.
Old 05-07-2013, 09:12 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Are you sure they didn't say 14.4 volts? The alternator is capable of pushing something north of 150 amps, but low teens may be appropriate for the ECU trying to charge a fully discharged battery (say, 1/10 rate for an 80aH battery, plus other car electrical loads). Still, off the top of my head, I'd expect more than 14 on a running car with a dead battery.
If you have a dead cell in the battery, it doesn't really matter what voltage you feed it, it still won't come up.
So, with the engine running, what voltage do you see between the jumping terminal under the hood and a ground?
Old 05-08-2013, 09:53 AM
As it turns out the battery that was in the car is just a conventional lead acid battery. I think that is the problem.
