Old 05-08-2013, 12:16 PM
Aakash Aakash is offline
Mein Auto: 328i
Question When can you push the car?
Hello,
I got a 09 328i...I love the German engineering of my car but can’t figure out two things:
1. First, which genius designed the cup holder – different thread I guess
2. How do I know the temperature of the engine during winter times? Instead of that gauge, I have the fuel mpg gauge…
I live close to a highway, which I need to take for work. In the winter, I don’t want to push the car straight at highway speed without knowing if the engine is ready. Any way to tell, especially when wifey is taking the car, without looking at the secret hidden menu.
Thanks in advance...
Old 05-08-2013, 12:41 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Well, you can get a cheap ELM 327 Bluetooth OBD connector from eBay and use the Torque app on your smartphone. That will at least give you water temperature.
It takes a while for it to heat up. In the wintertime, mine is still not at full oil temperature after 20 minutes at 75 mph. It takes at least 7 miles at 75 mph before I come off the 160 degree peg on my oil temperature gauge on a below freezing winter day, especially if the temperaure has been in single digits overnight. Dallas may be less of an issue.
Old 05-08-2013, 12:47 PM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Originally Posted by Aakash View Post
Hello,
1. You got me. Everyone that gets in the car thinks they're cool, but for someone that has to live with them, especially when transporting TWO beverages, it's a pain.
2. This one CAN be tricky, but first: Do you have an iDrive system in your car? The monitor in the middle of your dashboard? If so, you can check the oil reading there, if it's reading your oil level, it means that car's basically warmed up enough.
Otherwise follow the basic and simple procedure of driving about 20-25 minutes in stop and go traffic, or 15'ish minutes on the highway with temperatures above 50 F. Then, you nail it like you've stepped on a nail with bare feet.
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 05-08-2013, 12:56 PM
Mein Auto: 328i
Dallas is not too much of an issue in the winter but might be moving to Michigan, so need to be prepared and train the wifey will ahead of time...
Sorry, no iDrive in mine...Does the car have some sort of warning if the engine is too cold? I know they have one for overheating but didn't see anything in the manual...
Old 05-08-2013, 01:10 PM
BiHoTTo115's Avatar
No, there is no 'cold warning', but there is a chime that you'll hear randomly and you'll see a snowflake icon in the center of the speedometer, that'll alert you that it's below 37 F, so that's one sign that it is cold outside.
Basically just drive it for a bit before punching it in colder weather, and less in warmer weather. If you live RIGHT near the highway, you won't be slamming the pedal ever (my luck unfortunately).
Old 05-08-2013, 03:16 PM
AzNMpower32's Avatar
Tar Heel Faithful
Regarding the warm-up, these cars have electric power steering pumps so the warming is rapid. Plus, unless you're going straight to 160km/h or over 3500rpm right off the bat, I wouldn't worry. I also live right next to the highway and have to get drive it up to 110-120km/h while the engine is bone cold (<40°C)
Old 05-08-2013, 03:48 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
As long as you use the recommended oil you don't have to worry about driving at highway speed right away. Just worry about keeping the routine maintenance up-to-date and you should have no trouble.
I live just under a mile from the freeway and we have long cold winters here. I have a 25 mile commute that I have been driving for over eleven years with great service from a number of cars (170K Toyota, 211K Mitsubishi, 190+K on BMW e36, 215K on Dodge, 238K on Ford, 98K on BMW e90). Some of these I used in Washington DC metro area for 5 years and St. Louis area for eleven years before that all with similar commutes. I have discovered that the key to long trouble free service is using quality oil and doing maintenance on schedule. Maybe I am just lucky but I have never had a catastrophic engine failure. I don't baby the drivetrain either. Drive the car like it was designed to be driven and pay attention to what it tells you by listening to any strange or unusual noise or vibration etc.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 05-08-2013, 08:55 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Electric water pump, not power steering.
Old 05-08-2013, 09:50 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Hello,
I got a 09 328i...I love the German engineering of my car but can't figure out two things:
2. How do I know the temperature of the engine during winter times? Instead of that gauge, I have the fuel mpg gauge…...
I live close to a highway, which I need to take for work. In the winter, I don't want to push the car straight at highway speed without knowing if the engine is ready. Any way to tell, especially when wifey is taking the car, without looking at the secret hidden menu.
Highway driving no prob - car won't let you damage it unless you over-rev w/manual.
But to thrash it....best wait until up to normal OIL temp. Somewhere there's an oil temp sensor....you can read it if you wish - N52 has a 2AZ oil condition sensor just like N54, prob in oil pan - RTD temp sensor is part of it.
And now I see: the 1AZ Oil pressure switch/engine oil temperature sensor. Ta-da!! There's the other temp sensor I thought was installed, and it is for N52 and N54. Have no advice on where it's mounted or how it works - sorry!
Old 05-08-2013, 10:33 PM
DarrenDanger DarrenDanger is offline
BMW ****
Mein Auto: 2011 328i xDrive
If it gets really cold where you live, get a block heater. when idle rpm's drop, she's ready to go. As posted above, use the recommend oil - no worries.
The manual says " Set off right away" or something like that. The best way to warm up an engine is to drive it. Just accelerate smoothly.
Old 05-09-2013, 07:58 AM
Mein Auto: 328i
awesome...thanks everyone for a quick reply...now, who do we send the cup-holder complains to???
Old 05-09-2013, 02:48 PM
Tar Heel Faithful
I can't remember the last time I used cupholders in my X3.
Old 05-09-2013, 07:18 PM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
The cupholders may look cheesy but they work fine.
Old 05-09-2013, 07:42 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
My typical work commute is 8 miles/15 min so basically I never get to "have fun."
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
Old 05-10-2013, 06:43 AM
335i Driver 335i Driver is offline
Mein Auto: 335i
I try to keep it below 4k rpm until I see at least 190 on the oil temp gauge. That takes at least 12 min on a normal day. If it's really cold, can take up to 18 min.
Old 05-10-2013, 07:55 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
I love the e90 cupholder. It is perfect reach for my arm. It is out of the way. When not needed it's hidden. The only downside is when the passenger one is out, and the passenger exits/enters the car I always worry that she will hit it with her leg.
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 05-10-2013, 08:03 AM
fun2drive's Avatar
BMWCCA 149159
You have a 328 so you don't need to worry about blowing turbo seals beating on it when the oil is cold but like anything mechanical it is better to take it easy on it when cold starting out. If you jump right on the interstate then you need to get up to speed to not be a nuisance. My M3 with 284K miles lived a gentle life in Az and Fl now in Oh but again not turbocharged and used factory synthetic oil changes.
Cup holders are adequate and the Germans actually Europeans in general don't get the cup holders for good reason. If you drive much at Autobahn or Autostrada speeds you would understand why.
Old 05-10-2013, 08:18 AM
BiHoTTo115's Avatar
As a European that lived in Germany for several years, I need cup holders! I don't really mind the E90 ones, but like Furb said, I worry about someone smacking it with their knee, then I'm out like $80 or whatever they cost (been a while since I checked).
Even if it's just for water (only thing I really allow in my car), I need a solid cup holder. I like how the F30 does it.
Old 05-11-2013, 09:11 AM
Bemo's Avatar
That's about the ONLY thing the F30 does well!
It's a small price to pay to endure the somewhat inconvenient cup holders, in exchange for having the hydraulic steering and NA6 engine.
Of course BJ feels otherwise since he bought a souped up golf cart for 50+ large...
2011 328xi
2011 535xi GT
BMW CCA
Old 05-11-2013, 09:28 AM
R608 R608 is offline
Mein Auto: '11 328i M-Sport (6MT)
1. I'll never get why people complain so much about the cup holders. They aren't an engineering marvel, but I've seen so many far worse designs, and the ones in my old Passat were virtually unusable. Inserting or removing a soda can required two hands so you didn't break the stupid thing, and they were no more than maybe half an inch deep. Aside from passengers needing to watch their knees, I find these to work just fine.
2. As was suggested earlier, the easiest solution is to try checking your oil level, and you don't need iDrive to do it. Just check the menus using the rocker switch and button on the turn signal stalk. I don't know how close it has to be to normal operating temp to register, but my admittedly very unscientific sense is that it's similar to reaching normal coolant temp. (If anyone can say more specifically, I'd be interested to know.) In any case, it's clumsy, but it's free and always available.
Old 05-11-2013, 09:21 PM
ProRail ProRail is offline
&amp;quot;Clunker&amp;quot; *****
Mein Auto: 1999 BMW 528A-220K-traded
So you only drive to and from work? Bummer. Give your bimmer a decent run once in a while.
Old 05-12-2013, 01:01 AM
Renzame Renzame is offline
Mein Auto: Future 335i Owner
Just be gentle till you get used to it.
Old 05-14-2013, 08:19 AM
BiHoTTo115's Avatar
Well that was basically all I was saying, I like the cup holders there, and I like the instrument cluster as well.
Other than that, paying anything more than 30K Even for an F30 328i is highway robbery. I'd rather get a decked out E90 328i than an F30 328i heh.
engine temperature
