E34 (1989 - 1995)
Old 05-08-2013, 12:56 PM
reza338 reza338 is offline
Mein Auto: 535i E34
low acceleration at low rpm
dear friends my car has a problem exactly the same as a below youtube url that i found it at you tube? what is the problem?
Old 05-08-2013, 09:48 PM
Bimmerfan84's Avatar
Bimmerfan84 Bimmerfan84 is offline
Mein Auto: 1998 528i
Well if you read the posts the guy found cracks in his distributor cap. He replaced it and everything was fine.
The posts in the video that is
Old 05-09-2013, 03:03 AM
Mein Auto: 535i E34
low acceleration
i changed my distributor cap but the problem is still remained
Old 05-09-2013, 06:57 AM
Mein Auto: 535i E34
Dear
i checked my air flow sensor based on attached file user manual ( air flow sensor checking M20/M30 ) the resistance between pin 2 & 3 changes steadily but from 500 ohm at full close rise to 900 ohm at 60-70 % of maximum movement of flap and again falls to 500 ohm with increasing of flap from 70 % to full open, is it logical? i think the resistance must be rise linear instead of sinus changing
Old 05-13-2013, 12:39 AM
Mein Auto: 1989 525i M20B25
If you want to test your AFM you need to apply voltage to it as shown here:
http://www.iprimus.ca/~trauttf/temp/AFM/
You should look into the other possibilities of what is causing your rough running problem as well.
Old 05-13-2013, 03:49 PM
Mein Auto: 535i E34
thank you very much for your guide & useful link
Old 05-13-2013, 07:34 PM
PlasmaE34 PlasmaE34 is offline
Banned
Mein Auto: E34
Paperplane 94, that's the best link on the old AFM and its design I've seen. And I have searched before.
I've seen your other links too. You are truly a sleuth I must say.
You probably have accumulated a long list of *good* links on potentially relevant topics. There's a talent/luck combo involved in this and you certainly have it. Would you mind starting a thread and posting all the good links that you've found over the years ? Kinda like a glossary. I think it would be a good archival thread and would be useful just to read through for knowledge. The thread would be referenced by yourself and other posters as situations come up.
Old 05-14-2013, 12:31 AM
Good idea, maybe in the future if I don't have too much work .
Old 05-14-2013, 05:22 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
There are already two stickied threads about problems and maintenance. If you see something that is too good to pass up you should contact the moderators and ask them if they will add it to the existing stickied topics
Back for another round already bobby?
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
