Old 05-08-2013, 06:34 PM
slemmer slemmer is offline
Mein Auto: '04 645cic '00 740i Sport
Hub centric spacer required?
Could someone advise if a 74.1 mm wheel hub bore will need a hub centric ring given the OEM spec is 72.56 mm? 1.5mm is quite thin and I'm not even sure if such a hub ring exists. Thanks.
Old 05-08-2013, 06:35 PM
ferny ferny is offline
Mein Auto: 06' BMW 650i
They sell spacers online, you will probably need it to avoid vibrations.
