Old 05-08-2013, 08:50 PM
328imd1 328imd1 is offline
Mein Auto: bmw 328i
Had Recall Done, Found Something Interesting In Trap...Photos!
Under the hood, in the removable plastic trap on passenger side that I periodically remove and shake out bits of leaves and twigs, and runoff from wipers etc, I found some sort of black plastic clip that must have come loose during battery recall fix.
It's about 2 inches long, black, and top side looks like an elongated "H."
The underside has a small rounded channel with several steel- colored "teeth."
Any idea where it belongs?
Can I just clip it back on and save a trip to Dealer?
Thanks...
Old 05-08-2013, 09:07 PM
GarySL's Avatar
GarySL GarySL is offline
Mein Auto: '08 335xi (E90)
Any photos?
'08 335xi (E90), 6MT, Arctic/Black, ZPP, ZSP (18"s), ZCW, CA, PDC, i-Pod
Ordered: March 7, 2008
Built: March 17, 2008
At port: March 19, 2008
Shipped on Graceful Leader: March 21, 2008
Arrived Port Hueneme: April 11, 2008
At dealer's: April 19, 2008
Delivered: April 21, 2008
Old 05-10-2013, 06:56 AM
DougN's Avatar
DougN DougN is offline
Original Owners Club
Mein Auto: '10 E93;'66 MGB;'73 240Z
In this case, a pic is indeed worth 1000 words...
Doug
________________________________________________
2010 328 E93 Titanium|Black|Aluminum
Other Cars:
1973 Datsun 240Z
1966 MGB Roadster
Old 05-10-2013, 07:29 AM
3two8iguy's Avatar
3two8iguy 3two8iguy is offline
Mein Auto: 2011 E90 328i sedan
Call the dealer and speak with the service manager,I seems like "SERVICE" is slowly deteriorating at BMW,I refuse to put up with anything less than perfection,isn't that the reason we bought our Bimmers?
Old 05-10-2013, 05:07 PM
db2761 db2761 is offline
Mein Auto: 2008 335i Sport Coupe
my money is on the cap that covers the (a) windshield wiper, mostly cosmetic as I understand..
best,
Db
Old 05-11-2013, 12:31 AM
DSXMachina's Avatar
Bimmerdex 7.4!
I don't think any work is done under the hood for the recall you mention. Is there a possibility the alien device was used to retain the sound pad attached to the underneath of the hood? You don't list the year of your 328 so I don't even know for sure you have the pad.
Old 05-11-2013, 07:03 PM
Mein Auto: bmw 328i
It's a 2011 328i sedan...
Poking around under the hood, I may have discovered what it is...
There is a thin black rubber tube that runs directly over the passenger side trap...
I think it is the hose that delivers the windshield washer fluid to the passenger side nozzle...
This black H-shaped clip may sit right under this black hose...
It seems to clip on to this little black plastic projection that sits above the trap, and seems to support the hose, almost like those little white plastic stands that sit under a pizza box lid..
Sorry for no photos...
Can anyone confirm??
Old 05-12-2013, 05:15 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
I feel like it is a year 1887 with the Internet access. Can someone teleport me back to 21st century.
Even a cell phone picture might help your quest, unless you want to look for the part at realoem.com
BMW CCA Member 454031
Save the manuals
Old 05-12-2013, 05:57 AM
3284me's Avatar
3284me 3284me is offline
Mein Auto: 2011 328 xdrive
Ahh, 1887 times were so much simpler then.
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
Old 05-12-2013, 08:41 AM
Perhaps, the alien part is the cover for the power terminals from the battery and to the alternator? Nearly "h" shaped..
The suspense is killing me...
db
Old 05-12-2013, 04:38 PM
Mein Auto: bmw 328i
Only 500 views later...
Photos!
Old 05-12-2013, 05:50 PM
luskombi luskombi is offline
Mein Auto: 2007 328i
There are several of those under the hood. Sounds like this one lets the pass side windshield washer hose rest on it secured with black cloth tape.
Old 05-12-2013, 07:08 PM
Awesome!... now.. I spy, with my eye...?
lol
Old 05-12-2013, 07:48 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Retaining clip. Fell in there on the assembly line.
Old 05-12-2013, 07:52 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Right. Notice the raised boss with the corrugations across it, a couple inches in front of the hose clip? That's where another one of those clips would attach in a different application.
Old 05-12-2013, 08:52 PM
Mein Auto: bmw 328i
The washer fluid hose is sitting there with a few strips of black cloth tape wrapped around it, strips doing absolutely nothing now...
So this clip sits on the black corrugated projection and then is taped to and supports the hose correct?
It makes sense since I had the wiper blades changed at the recall visit as well...
Clip must have come loose then...
Thank you for saving me a trip back to the dealership...
Old 05-13-2013, 05:43 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Tape it for factory look.
Note; Those clips are already on the tubes and wiring harnesses when the parts are put into place on the assembly line. It's very strange that the OP found one which looks like it was never attached to anything. Maybe there was an assembly line change and those were being added to prevent chafing until a running change was made to the tube or harness assembly.
