Heat shield for the 335is hood??? - Bimmerfest - BMW Forums
Old 05-09-2013, 03:18 PM
jimduke jimduke is offline
Mein Auto: 325ci
Bought a 2012 335is with 5000 miles. Has no heat shield attached to the underside of the hood. Dealer says they are made without them.
Sound legit to you guys?
Old 05-09-2013, 03:24 PM
daytrader daytrader is offline
Mein Auto: 2010 E92 335i
Yes, but you can buy one and retro fit the last I knew, if you want one in place. My 2010 didn't come with one. Paint damage because of heat has not been an issue, plus I like the sound of the turbo noise coming from under the hood undampened by a shield.
Old 05-09-2013, 03:43 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is online now
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
Yes. The under-hood sound insulation panel was deleted in '09 or '10 as a cost-cutting measure. Should you want to retrofit it, the part costs ~$80 with clips and installation takes all of five minutes.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 05-09-2013, 05:27 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Many posts 'bout that - look in this forum and you'll find 'em with part numbers, experience installing, etc....
Wasn't the Professor our expert?
Old 05-09-2013, 07:46 PM
BuraQ's Avatar
BuraQ BuraQ is offline
Moding is Addictive
Mein Auto: DCT 335is BQ Tuned
LMAO ! Dude I was thinking someone ripped mine off till I saw this post
Old 05-09-2013, 11:17 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Yep....'09 335 with no heat shield.
Sent from my DROID2 using Bimmer App
Old 05-13-2013, 06:10 AM
smbmw3 smbmw3 is offline
Mein Auto: 1998 M3
Is it actually a heat shield or an insulating pad? If it is insulating, that dang engine runs so hot I wouldn't add one.
Current: 1998 BMW M3
Former: 2007 335i and 328i
Old 05-13-2013, 07:04 AM
Zeichen311's Avatar
Well if you think about it, those are the same in that both reduce the amount of heat that escapes the engine bay. If anything, a heat shield would be worse because it reflects heat rather than absorbing it.
Officially, the pad is sound insulation.
Old 05-13-2013, 07:05 AM
Sound.
Old 05-13-2013, 09:47 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Its for sound...hood gets real hot, put your hand on it. Do you want to keep that heat inside the engine compartment or let the hood radiate it off?
Kevin
CURRENT:
2018 BMW 440M-Sport MPPSK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
477 WHP of BURBBLES
HOME FROM PAINT
Old 05-13-2013, 12:36 PM
BB_cuda's Avatar
BB_cuda BB_cuda is offline
Mein Auto: 2011 335D Msport
Errr um you mean convect the heat off. Even sitting still, there will be more convection wafting upwards. At 80 mph, a ton of convection is happening under the hood as well as above it. Radiation heat transfer starts to be more significant when the delta T is 200F or more. Now if you convert your 3 series to spaceship and fly it where no atmosphere exists then radiation is mucho importante.
Old 05-13-2013, 12:51 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Way too expensive a proposition, what with cabin pressurization and oxygen supply issues, let alone addition of re-entry tiles, etc. Much easier to just bolt on a couple aftermarket flux capacitors and be happy with time travel.
Gotta go, I'm heading back to 1978 to convince young Christopher Bangle that his true calling is to go to work for Audi.
Old 05-13-2013, 01:12 PM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2013 X5
Cabin pressure is no problem, that's why BMW switched to rubber door seals instead of felt.
2013 X5 35i
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 05-13-2013, 03:15 PM
Papers lifted on rising convective air current from warm radiator
Kevin
CURRENT:
477 WHP of BURBBLES
HOME FROM PAINT
