Old 05-09-2013, 03:36 PM
DHoffmeyer's Avatar
DHoffmeyer DHoffmeyer is offline
Mein Auto: 99 528i
Thumbs up Original fuel filter change at 229k
Going down my list of maintenance items for my recently acquired '99 528i, I changed my fuel filter today and was shocked to see a Feb. 1999 date stamped on the side of the original Kayser. After changing it, I noticed a very slight increase in responsiveness, but nothing overwhelming. Relieved more than anything.
I wonder if this is close to some kind of record?
Old 05-09-2013, 03:52 PM
musa's Avatar
musa musa is offline
Mein Auto: 528ia , X5 4.4 S, 335i cp
It's possible the item was installed long after the manufacture date which is likely the date you see stamped on the item itself. The item is not necessarily the original one that came with the vehicle.
Old 05-09-2013, 04:11 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
That is possible. All four clamps had BMW markings, one hose had a BMW mark on it, so a filter change could have been done by a dealer using a NOS Kayser/ BMW filter years later. The car is an April '99 unit. Hard to tell for sure. It seemed the gas coming out the "IN" side was fairly dirty though, so good riddance.
Old 05-09-2013, 04:26 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
The car
The BMW hose
Date stamped on the filter
New Mann and old Kayser filters
Old 05-09-2013, 05:15 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I always compare fuel filters by blowing into both new and old, and observing the difference. Blow in the direction of flow.
Old 05-09-2013, 07:33 PM
mucho mucho is offline
Mein Auto: 1999 528i and 2012 X5
i have 99 528i 176K
i got mine brand new in 99 and still have'nt change the fuel filter, and still getting
approx 480 to 500 miles to a tank.
Old 05-09-2013, 08:14 PM
A clogged filter has nothing to do with fuel mileage. It DOES have to do with engine performance. At some point the filter will clog up and begin limiting engine performance. If it gets bad enough, you'll need to call AAA to drag the car home.
BMW now begrudgingly allows a 100k mile service interval.
Old 05-10-2013, 12:43 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
Edjack is correct, plus anything that keeps your fuel pump from having to push fuel through a backed-up slog is worth an hour and a few bucks.
Old 05-10-2013, 01:52 PM
AH673000 AH673000 is offline
Mein Auto: 1997 BMW 528i
My bet is it is original, and my bet is it will give us all a great insight if you cold cut it open and unfold the filter media. Mine is original ( 16) years.... 99% run on Chevron or Mobil gas .
The condition may tell you how your tank and fuel pump might look .
Old 05-10-2013, 04:06 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
+1, it probably is original. Everyone's use is a bit different. While replacement of the filter is best done by 90k miles, if you go by statistics and the "bell shaped curve", there are extremes at each end, where a filter plugs up in 20 to 30k miles and people that can go 200k plus with no issue.
Obviously trying to test the extreme end is not advisable, as we have seen on this forum several folks who never changed their fuel filter and end up changing both the filter and expensive fuel pump at high miles, as the plugged filter took out the pump from all the strain it caused...
That would be the reason for a prudent fuel filter change every 90k to 100k to prevent fuel pump failure, as well as a plugged filter simply stranding you on the side of the road. That is why it is called "preventive maintenance".
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, Bilstein B14 PSS coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 05-10-2013, 05:51 PM
Increased Fuel filter longevity = never allowing tank to going below 1/4 full + use only quality gasoline from a tier three supplier .
Never have experienced a fuel pump or fuel filter failure in 50 years of driving ..... And the BMW filter is huge.
Filter failure is directly attributable to the owners breaking one of the above rules.
There I said it.....
Old 05-10-2013, 08:43 PM
AV8R4AA AV8R4AA is offline
Mein Auto: 2000 528it 2004 X5 4.4i
I always change the fuel filter on a new-to-me car.
Since the one coming out is saturated, and the new one is bone dry I always
thnk "wow I changed this just in time"
I think saturated fuel filters always seem hard to blow through.......
I love my BMW 528it
Old 05-10-2013, 08:49 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
Yep, well the old Kayser fuel filter is drying out so I'll eventually get it open and photograph the contents.
Old 05-11-2013, 04:26 AM
helpmyfive helpmyfive is offline
Mein Auto: 528i
I don't think mine was changed (the PO didn't do crap!) and I'm up to 274,000 now. I think I should change mine just because. If I remember to I'll post back.
Old 05-11-2013, 09:38 AM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Comparison is only meaningful if both filters are dry, or wet. Wet will always be much harder to blow any air through, but waiting for the old filter to dry out completely could be a matter of weeks.
Old 05-11-2013, 10:09 PM
Top tier supplier or not, many gas stations have issues with their tanks and other variables well outside the car owner's control. I rarely have ever had my tank go below 1/4 full and rarely if ever, stray from a top tier gas supplier, but I STILL replace the fuel filter at a reasonable interval. It is hardly worth testing the limits to me. But everyone is allowed their opinion.
Seriously, never change a fuel filter? 16 years? Do you believe the filter is designed to last the "life" of the car, whatever that might be? Your sample of one is hardly definitive of your practice...and there have been more than a few threads of folks here and on bimmerforum replacing a fuel pump that had the original filter fuel filter as well (the filter did not necessarily fail, it was actually doing its job of trapping contaminants and finally plugged up and burned up the fuel pump). And filters do break down simply from age. Ever seen an oil filter that has been in service for too many years, even though the miles may not be that great? The paper breaks down...
Old 05-12-2013, 11:09 AM
Ok , so I called my son ( 07-528) and asked him if he saved the gas filter he changed recently with his fuel pump.... 175k original stuff .
We cut it open . Filter had exactly zero rust , dirt , or other debris in it. What it did have was a thin coating of black powder like deposit on the paper. The paper filter was in excellent condition .
Reporting from Philadelphia ..... Changing fuel filters at 50k is bunk....
Old 05-12-2013, 11:49 AM
The black coating is on the "outer" side, and I'm told it's like that new.
Old 05-12-2013, 12:59 PM
First a typo correction... Son's car is a 1997 528i ....
Thanks for the info on the thin black powder coat on the inlet side of the filter..... Looked like activated charcoal or something.
The BMW filter media is huge..... Compared to older type gas filters it must have maybe 50 to 100 X more area.
My guess if a filter plugs it would be a singular event .... From a low volume station with old equipment or a some other one time event.
This filter was clean .... Was made in Germany.... Had BMW on it .... A date .... And was quality made. Inside was a plastic distribution baffle at the inlet... It also was spotless .... No deposits.
Old 05-13-2013, 11:27 AM
Okay I agree with not changing at 50k.
I change at 90k. I am currently at 195k miles....changed at 90k and 180k. Never cut one open...the peace of mind is enough for me....
Old 05-13-2013, 11:36 AM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
I can't believe any car going that many miles on the original filter.
Old 10-13-2013, 06:58 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
http://www.bimmerfest.com/forums/pic...ictureid=44320
Could have been a NOS replacement, but so much of this car is original, I think the filter was as well. Power steering pump was original. Much of the suspension is original
Old 10-14-2013, 04:46 AM
Flybot's Avatar
Flybot Flybot is offline
Mein Auto: '98 528
There is about 3 feet x 10 inches of filter paper in those things. They are good for a long long time.
Old 10-14-2013, 06:38 AM
professorman professorman is offline
Mein Auto: 2000 525i
I just added fuel filter change to my 'to-do' list. I am feeling lazy... Is there a link to instructions for filter change? Part number for replacement?
Old 07-20-2014, 07:26 PM
DHoffmeyer's Avatar
Mein Auto: 99 528i
Better much later than never on this, here's the interior of my old fuel filter. Be back under there tomorrow because there is a substantial gas leak in the same general area.
fuel filter
