Old 05-10-2013, 10:34 AM
aneal000 aneal000 is offline
Mein Auto: 2007 335xi
Half Engine Light - lack of power
I spent the last two hours searching and reading and I'm still not sure what's going on.
2007 335xi with Dinan stage 2, (no oil cooler), 90k miles, HPFP and injectors were replaced at 84K. I've only owned the car for two weeks and 1k miles. Last night during a bit of spirited driving (~5 miles) the half engine light comes on and I loose some power - the throw you in the back of your seat boost power. Was only a mile from home so went home and parked it thinking it was probably this "limp mode" everyone has suggested, however I never saw the oil temp climb above ~250, it usually runs around 235-240. Started it up this morning and light was off. After some warmup miles I tried getting on it and it still was lacking the hard pull. At this point the light came back on. I've repeated this a few times with the same results.
I have a code reader, but it is a cheap one that I don't believe pulls BMW codes - It shows no codes. Although, thinking out loud, I had turned the car off/on and the dash light was off when I tested. Either way, no codes. I can try tonight to get a code while still running.
From what I have read this is the DME1_DDE1 - Engine Problem! Loss of Power light. It appears to be caused by VANOS solenoids, although I haven't seen anyone describe the same loss of power because of this. HPFP issue, although it runs smooth and doesn't act like it is going die as others have suggested - just no strong pull. Which lead me to believe it could be turbo or wastegate related. I come from a background of BMW's but this is my first turbo experience and I'm pretty ignorant to the intricacies of their operations.
Any thoughts?
Old 05-10-2013, 10:43 AM
sean5450 sean5450 is offline
Mein Auto: 335i 09'
Re: Half Engine Light - lack of power
I had a similar experience a couple years ago. Felt like I was driving a non turboed car. Turned out to be a bad vacuum hose that was causing the boost leak.
Sent from my SGH-T999 using BimmerApp mobile app
Old 05-10-2013, 10:55 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by aneal000 View Post
Any thoughts?
This
Old 05-10-2013, 11:48 AM
Originally Posted by CALWATERBOY View Post
Yeah, I saw where you posted that in another thread. Is that one of those must have tools for owing this car? Down deep I was hoping it was a common problem that many have experienced and had a known solution. Apparently not so much.
Old 05-10-2013, 12:23 PM
Is is must-have, for DIY or the curious, wanting t'ghost the dealer, always prudent.
