Old 05-10-2013, 01:16 PM
nicko360 nicko360 is offline
Mein Auto: s2000
528i Wagon Help Needed. MAF not reading
Ok so long story short I bought this wagon shifting hard, found trannys available for $500 and went ahead and swapped one in figured quick fix?
But it still runs and drives the same, I ran the codes and it was throwing Mass Air P0101 and has the sign on the dash for transmission limp mode
Next I try a new mass air sensor - no luck
Upon further investigation (and a little research) I found out the last person to work on this car switched the alternator plug and the mass airflow plug
I returned the plugs to their proper places, reset the codes with a scanner, and reset the battery
Still the same results, throwing a constant cel for mass air and instantly going into limp mode
Any help is appreciated, not sure what to try next - already inspected for vaccuum leaks but figure it might be a computer issue or wiring since as soon as the cel is erased it comes back?
Thanks!!
Old 05-11-2013, 12:24 PM
poolman poolman is online now
Mein Auto: 525i station wagon
If the plugs were swaped--wouldn't the plug from the alt be sending current into the OBC . It might have burnt that circut up--or if your lucky --you may have a fuse blown. The Maf will help the way the tranny shifts
Old 05-12-2013, 12:11 PM
Mein Auto: s2000
does the MAF have its own fuse?
