Old 05-10-2013, 04:46 PM
taytuck123 taytuck123 is offline
Mein Auto: 1998 528i 1995 325i
hid light conversion
My 1998 528i did not come with factory angle eyes, I was giving a pair of factory hid, angle eyes self leveling xenon lights is there any way to convert my car ? Thanks kelly
Old 05-10-2013, 05:08 PM
Mason_E39 Mason_E39 is offline
Anti JDM
Mein Auto: 2001 BMW E39
What are you trying to convert to Kelly?
2001 BMW 530I
1968 Chevrolet Camaro
Old 05-10-2013, 05:20 PM
lights
I want to replace my factory lights with factory hid angle eyes with self leveling, but my plugs don't match, is there any way to convert.
Old 05-10-2013, 05:24 PM
Anti JDM
Yes you can. Its not the wrong or right way but the cheapest and easier route to take would be to cut the connectors off and connect ground with ground and hot with hot. But I would suggest taking it to a local stereo shop first before you cut anything just for the simple reason I cant see 100% of what your doing.
I hope this helps in some way.
2001 BMW 530I
Old 05-10-2013, 05:27 PM
ok, great as long as there is a way I have the will.I will take it to someone to look at it thanks.
Old 05-10-2013, 05:32 PM
Anti JDM
Hopefully the bulbs are the same. If not, you may have to buy another pair of headlights. Because I THINK Xenon are different sizes then HID. But dont take my word for it. Like I said have them check it out.
2001 BMW 530I
Old 05-10-2013, 06:03 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
Xenon=HID
Old 05-10-2013, 06:05 PM
Anti JDM
Originally Posted by King540i View Post
Xenon=HID
Really? I have never had Xenon so I wouldnt know but thanks for clarifying me
2001 BMW 530I
Old 05-10-2013, 07:33 PM
Elvis530i's Avatar
Elvis530i Elvis530i is offline
Stimulus Package
Mein Auto: 2002 530i
You can't just cut and plug. You're going to get a fault code because your lighting control module thinks you have halogens and the stock xenons will make it think there is a bulb out. It's more than just the lights. Aftermarket xenons have resistor packs that trick the LCM into thinking things are okay.
2002 530i | Black/sand | Rondell Style 81s: 18x8.5 Front 18x10 Rear | Koni FSD | Eibach Pro-Kit | Zimmerman X-Drilled Rotors | Axxis Deluxe+ Brake Pads | StopTech SS Brake Lines | 50w 6000k Xenon Lows/LED Fogs/Phillips Luxeon LED DRLs | Angel i Brights v3.0 | Solaris Invisibulbs | Shadowline Trim | ///M5 Trunk Lip Spoiler | 35% Madico Tint | Dynavin D99+ ///M3Evolution | Backup camera | Intake Muffler, Front Plate, Badge & Cup/Coinholder Delete | Klasse AIO+SG
Old 05-11-2013, 12:38 AM
Xenon= the gas inside the bulb
HID= high intensity discharge
HID is the general name given to all lights that use a ballast and run on gas on the inside of the bulb. Xenon is a specific type of gas used inside the bulb.
As elvis stated, you need the ballasts to make the lights work.
Old 05-11-2013, 08:28 AM
rdl rdl is online now
Mein Auto: 530i 2003
Here is a link to BMW instructions for retrofitting Xenon/HID headlights c/w automatic level control
http://www.gavandkel.co.uk/PDFs/276en.pdf
It cautions that details may vary depending on the specific car. But the guide will at least give you an idea of what is involved. The instruction notes that headlight washers must be retrofitted if not already installed. This requirement is a European standard, not required in North America.
A related link with E39 retrofit guides for a wide range of options/features.
http://www.gavandkel.co.uk/E39.html
Main page with retrofit links to a number of BMW platforms.
Regards
RDL
Old 05-11-2013, 10:46 AM
theWalkinator theWalkinator is offline
Mein Auto: 2002 BMW 540iA
Saw on the other forum this guy did this head lights, pretty cool, you may want to consider to use his service:
Old 05-11-2013, 11:13 AM
King 5's Avatar
King 5 King 5 is offline
Send a message via AIM to King 5
Mein Auto: 1997 BMW 528i
Thats pretty neat! I don't even want to imagine how much he would charge for such a project
1997 BMW 528ia 2/97
2004 BMW 330ci 4/03
2008 BMW 335i 3/08
Old 05-11-2013, 12:07 PM
Don't know how much he will charge a project like that, you can certainly send him an inquiry, he is on facebook and he does audio. lights and interior work, here is his contact info:
https://www.facebook.com/SuperiorMobile
http://www.13r1an.com/
