Old 05-10-2013, 05:46 PM
thedonesco thedonesco is offline
Mein Auto: 2008 335xi
Help with brakes 335xi
08 335xi
I need some clarity my front brake pads light came on for being worn out
I put put new pads in but Iam having trouble resetting the light
According to the dealer I need to change the pad sensor every time I do a brake change
Is this true? Can i reset it some other way
They said the sensor really cheap 25 but I Juss want to make sure
Old 05-10-2013, 05:59 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
The warning light comes on when the rotor abrades through the tip of the sensor, destroying it. You must replace the sensor.
It is a good idea to replace the sensor whenever you change pads, whether it has tripped or not. It is designed to be used once and may not remain secure when transferred to new pads.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff
   N47 35' 30.13" E11 10' 33.36" - End of break-in...you can guess what came next. BMW CCA
Old 05-10-2013, 06:03 PM
Kamdog's Avatar
Kamdog Kamdog is offline
<- Bailey
Mein Auto: 2008 535i
My indy says to change the sensor with the pads, it is just good practice to do so.
535i, Monaco, Cream, Light Poplar, Comfort Seats, PP, Nav, ED.
Old 05-10-2013, 09:56 PM
chopin1012 chopin1012 is offline
Mein Auto: 2006 BMW 330i Sedan
Re: Help with brakes 335xi
You must change the sensor every pad change and then reset the mileage indicator. Unlike the E46, the E90 sensor has more than one wire that gets worn through by the brake pads; that's how it's able to estimate miles left in the pads. On the E90, even if your brake warning light doesn't come on, you need a new sensor.
Sent from my Nexus 4 using BimmerApp mobile app
Old 05-11-2013, 08:29 AM
thank you for the info i will buy a new on its only like $25 at the stealers
Old 05-11-2013, 01:30 PM
Ok so I did the brake sensor change and the light still on any info on how to reset it
Or do I have to take it to BMW
Old 05-11-2013, 01:35 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
lol I'd have sent you my fronts if you wanted my indy looked at me confused when I paid for fresh brakes and mine were still good over squeaks and weird feelings and also the rust
Old 05-11-2013, 05:28 PM
I don't remember off the top of my head, but you can search here or Google and find instructions.
Old 05-16-2013, 07:26 PM
Zeichen311's Avatar
This is partially incorrect. The CBS system estimates pad usage computationally, using the expected service life of OEM pads and integration of braking force, wheel speed, brake disc temperature (also determined by a computational model) and other variables over time. The sensor does not contact the rotor or wear through until the pad material wears to the minimum thickness.
