Old 05-10-2013, 07:57 PM
bad540i bad540i is offline
Mein Auto: 1998 BMW 540i
1998 E39 540i Stalling
I have read and searched for possible problems and come up with nothing. My 540i that i have just purchased is stalling when i start it up. It is doing this about 50% of the time. When its going to stall nothing can stop it even if i try to keep the revs high it will still stall. After it stalls it may stall the next few times i try to start it but it will never take more than 5 times before it starts. General driving is fine although it has stalled twice while driving when i have been slowing down at low revs. I have cleaned the MAF using CRC MAF Cleaner. And i have cleaned the seized ICV using TB Cleaner.This has not made the stalling stop although it has made the car run smoother. What do I do next ? Thanks In Advance!
Old 05-11-2013, 10:01 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Does the ICV rattle when you shake it? Sometimes cleaning doesn't help, and the valve must be replaced.
Read for pending codes, and report back.
Old 05-12-2013, 12:53 AM
yeap it does rattle ..
Im getting a diagnostic scanner this week and will that tell me whats up?
Old 05-12-2013, 07:48 AM
No, the best it can do is point you in the right direction. You still need skill in interpreting the data, based on knowledge of the workings of the car.
There may be a post or two that says, "When I got this code, I replaced the frammis, and the problem went away. Unfortunately, many who solved their problem never bother to report back to us, even though they received help from this forum.
Old 05-12-2013, 04:28 PM
ok ed jack when i get my diagnostic tool i will report back to you! also how do i change my fuel filter?
Old 05-12-2013, 04:51 PM
GreenTiger GreenTiger is offline
Mein Auto: 7/98 NonVanos 540iA
Fuel filter is a very easy change. Look up the DIY FAQs and as an added bonus, our prevanos fuel filters are very cheap!
Old 05-12-2013, 04:55 PM
esilvas esilvas is offline
Mein Auto: 2001 540i
My 2001 540i fuel filter was $65, how much is it on yours?
Just looking to have some fun while enjoying the ride.
'01 540i 6-Speed
Old 05-12-2013, 07:48 PM
About $16. Bosch brand.
Old 05-12-2013, 08:00 PM
can you link me a site to buy from. Im from nz
Old 05-12-2013, 09:18 PM
BMA:
http://www.bmaparts.com/searchitem.epc
RM Euro:
http://www.rmeuropean.com/search.asp...rd=13321702632
Autohauz AZ:
http://www.autohausaz.com/search/pro...er=13321702632
A few to get you started. Also try ECS tuning, EAC and others.
Old 05-15-2013, 12:04 AM
Hey guys i just bought a scanner although it isnt giving me a code it saying cam position sensor
What do io do ? does my car only have one cam position sensor? also it had a few more before i cleared them . One was hot film mass airflow sensor and another was cc continuous power supply! what do i do
Old 05-15-2013, 03:18 AM
I believe it has two Cam Position Sensors (CPS) like my 2001 540. There is one for each bank, i.e. each side of the engine. I would start by replacing whichever one threw the code. Bank 1 is passengers's side and Bank 2 is driver's side. Look in the Best Links for a DIY. If it is like my car, the driver's side is easier than the passenger's. but, either side is very easy to do.
Also, I write down my codes before clearing them so I know what needs to be fixed. That will help you as you diagnose the problem. After you replace the CPS on your car, rescan it.
'01 540i 6-Speed
Old 05-15-2013, 12:33 PM
borahatch borahatch is offline
Pre-Vanos M62s only have one CPS.
1998 540i
Old 05-15-2013, 12:53 PM
I see. I should have researched before responding. Thanks for the info.
'01 540i 6-Speed
Old 05-15-2013, 01:56 PM
is mine a pre vanos m62?
Old 05-15-2013, 02:43 PM
Yes
1998 540i
Old 05-15-2013, 02:51 PM
Most likely yes. If it is before build date 9/98 (IIRC) then it is pre vanos.
