somethong wrong with maf cps ned help!!!!! - Bimmerfest - BMW Forums
Old 05-10-2013, 10:12 PM
mr540i13 mr540i13 is offline
Mein Auto: 1997 BMW 540i
Ok so I have a 1997 bmw 540i at first my car was acting up came to find out that the maf was bad so I replaced it and everything was back to normal. But now my car won't start as soon as I turn my car over it wont stay on unless I step on the gas. And this time I even saw white smoke come out of the tailpipe. It did have the error code p0100 it it went away. Im thinking it could be the cps sensors? What do you guys think??
Old 05-11-2013, 06:25 AM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
What is error code 0100?
Is it starving for gas? Maybe a fuel filter is in order?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 05-11-2013, 09:26 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
P0100 Mass or Volume Air Flow Circuit Malfunction. Is this what caused you to replace the MAF?
Are there any pending codes stored?
A bad CPS will throw a P-code.
White smoke denotes water getting into the combustion chamber.
Old 05-11-2013, 09:52 AM
Well I found out what it was it was the maf that I bought off ebay. I know its cheap but as soon as I took it off and put of the old maf the car started up fine. I drove it for a while and nothing happened. And that was the only code that came up. Even the check engine light went off. So I have no idea what the problem is.
Old 05-11-2013, 11:28 AM
AH673000 AH673000 is offline
Mein Auto: 1997 BMW 528i
You forgot to introduce your new MAF to your ECS !
Kidding.... But I am always amazed how many of the sensors and other electronic stuff on the 528s needs to be " introduced" to your inboard computer.... I think the Germans are watching what is yanks are doing to their over engineered cars !
