Old 05-11-2013, 04:47 AM
bsion bsion is offline
Mein Auto: 2002 525i
Starting problem
Hi every body;
My e39 2002 was running completely normal till yesterday night, today I tried to start but it didn't, just hear a click and no cranking sound. Although the battery seemed to be normal, I thought it may be the dead and tried jump starting but no thing happened.
Is it the starter motor or what? Any advice?
Thank you.
Old 05-11-2013, 09:29 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
What is the overnight battery voltage? Have you checked the battery post and ground connections for being clean and tight?
Old 05-12-2013, 02:29 PM
Thank you Edjack for your reply, after deeper check, I found the battery fine but the grounding to the starter motor loose. Tightening a nut solved the problem.
Thanks again.
Old 05-12-2013, 04:14 PM
cdawg246's Avatar
cdawg246 cdawg246 is offline
Mein Auto: 1999 540i m-sport
Re: Starting problem
Im having the same exact starter issue but I cant get under under my 540i until I get my low pro jack from my boy--which nut loosened on you
battery, ignition problem, key, starter
