flat tire , new car only 3K Miles , i must replace the tire or can be fixed? - Bimmerfest - BMW Forums
Old 05-11-2013, 12:06 PM
pelo911 pelo911 is offline
Mein Auto: 335
335i F30
almost new car , only 3K miles
i have small screw in the left from tire , the air go out and i refill every day.
i went to discount tire , they told me i must order new tire.
the tires i have: Continental ssr - they look like rain tire (not sure)
do you have idea what to do?
if i must replace the tire , can i buy regular tire ? not Run flat tire
what brand and model i should buy?
Old 05-11-2013, 12:30 PM
Jerseyal Jerseyal is offline
Mein Auto: BMW 340xi
One poster said a local garage was able to patch his tire for $10-$15. its worth a shot.
Old 05-11-2013, 12:44 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I had Conti SSRs on my 335d. Picked up a screw in the tread. Went to a local Continental Tire dealer. They removed the screw, plugged and patched the hole. Drove it for another 25K miles, no problem. Cost: $16.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Dave 20T's Avatar
Dave 20T Dave 20T is offline
Moderator
Mein Auto: 320i (F30)
Tires should be of the same model for the same axle. Ideally, the same model for all 4. Because the car is new, I would tend to get the same model because you would be throwing away 3 new tires otherwise. If the tire was really lousy, then I'd buy 4 new ones. Almost new tires have some resale value but not much.
Old 05-11-2013, 01:39 PM
Mein Auto: 335
http://www.tirerack.com/tires/tires....r=Base%20Model
this is the tire i have , look like very worst tire for grip and driving enjoyment
don't know why the dealer install those tire on my 335i Sport line.
Old 05-11-2013, 01:43 PM
tturedraider's Avatar
Freedom isn't free!!
Originally Posted by pelo911 View Post
335i F30
Discount Tire will repair RFTs. If they told you it needs to be replaced that would lead me to believe they determined the tire is not repairable.
www.bmwcca.org
Old 05-11-2013, 01:58 PM
Mein Auto: 335
they didn't check the tire
just look the it's RFT and Conti SSR
and tell me they must replace it
Old 05-11-2013, 02:12 PM
russell07 russell07 is offline
Mein Auto: 2007 525I
It the screw is within about an inch of the sidewall of the tire most stores will not repair it. The screw would need to be in the center mass of the tread. Then a plug/patch can be used and the tire is good as almost new. You can tell just by looking if the hole is too close, they won't make the repair because they are liable for their work.
Tim
Old 05-11-2013, 02:35 PM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
I took my car in for a tire repair on an RFT and Americas Tire (same chain as Discount here in SoCal) said that they would have to check "their list". Apparently they have a 'do not repair' list of certain brands of RFT's. They came back, said my tire was OK to repair, and I was on my way. I know that if the nail/screw is in the sidewall no one will or should repair it.
Old 05-11-2013, 02:39 PM
ehchan ehchan is offline
Mein Auto: 2016 340i
My mom had this problem... Discount tire / America tire has a list of do not repair tires and the conti ssr run flat is on it... Another shop should be able to repair it though.
Old 05-11-2013, 04:06 PM
BlueF30 BlueF30 is offline
Mein Auto: '13 328i Sport Line
Just buy a plug kit and do it yourself. Easy fix.
Old 05-11-2013, 07:04 PM
Mein Auto: 335
i got a loaner car from BMW dealer for 3 days (it was around a month ago)
328i 2013 , i think also Sport line (my car and the 328i come with the same wheels so i assume it's also sport?)
the 328i come with a performance tires , not rain/snow tire i got
i enjoyed the ride quality much more in the 328 , much less noise and vibration , not so stiff like in my car
328i and 335i use the same suspensions?
i don't know if my car is so stiff and harsh because of the tires or maybe 335i have stiffer suspensions and this is the problem.
i red that RFT tires are more stiffer , it's true?
anyway i want to replace those rain/snow tire since i live in Houston , and also i want more sportier feeling and grip.
any recommendation? i hear Pilot PS2 or Super sport are great tires.
last question:
i need more power
what will be the best combination to get more? Down-pipe/ECU/intake
335i M sport have original rear tire 255/40/18 ?!
can i use this wider tire also on my car?
Old 05-11-2013, 07:24 PM
I have heard that about the Conti SSR. Wonder why that is?
www.bmwcca.org
Old 05-11-2013, 08:27 PM
bighorns's Avatar
Evil cider brewer
If you don't have M-sport these tires won't fit your rims.
Old 05-11-2013, 08:43 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
Conti SSR is old (GEN2) tires, surprising that they are using that. That's the tire that came on my 2006.
Old 05-11-2013, 10:02 PM
ard ard is offline
Resident Curmudgeon
dont rule out the possibility that the folks at the tire store sized up the customer and figured "we can make some $$ on this guy".
Read the document that came with the new tires/new car- it will say if the tire can be repaired.
Old 05-11-2013, 11:47 PM
Mein Auto: 335
bmw OEM Conti SSR , there is two models:
my tires (winter):
max performance:
i'm not sure if the very poor ride quality on my car it's a tires issue or too stiff suspension , someone have an idea?
Old 05-12-2013, 12:20 AM
pitzerwm pitzerwm is offline
Mein Auto: 335i Sedan
I took mine to Les Swab, no questions, just fixed. It was a small nail in the main part of the tread. Somewhere on the net, I found something that said if the hole was not near the sidewall and less than 1/4" they can be safely patched.
Old 05-12-2013, 10:46 AM
Mein Auto: 335
i went to other repair shop (firestone)
they fix it for 20$.
but i think anyway i want to sell all the 4 winter tire and get better tires.
can someone answer my questions above ?
for the Pilots super sport , this is the cheapest place i found:
http://www.discountedwheelwarehouse....5317&pID=25636
thanks
Old 05-12-2013, 10:54 AM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
thanks
Tires.
Get Pilot Super Sport. No matter how much you pay, just remember that they made you enjoy 45, 000 expense.
Sent from my SCH-I535 using Bimmer App
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 05-12-2013, 10:58 AM
Mein Auto: 335
forget to mention:
most of the time i like to drive hard , sport mode or turn off traction control
also i don't drive a lot of miles , around 10K miles a year.
so the Pilot Super Sport will be my best option?
what about my question about add more power ?
Old 05-12-2013, 11:56 AM
Yobyot's Avatar
Yobyot Yobyot is offline
Mein Auto: F30
335i F30
What you should do is read the freakin' tire warranty.
Shocking to me that you would go on a public forum and ask what you should do without even having popped the tire warranty CD into a drive to see if your tires are covered for road hazard.
The GoodYears on my F30 were -- and when I got a flat, the tire was replaced for nothing. I would be very surprised if the Continentals on your car also didn't have a road hazard warranty.
Are you in the habit of buying $50K+ items and not reading the warranties?
MY12 335i ZSL with a deep dive into the options list
Produced: 2012-06-22
ED: 2012-07-19; Arrived in Jersey City: 2012-08-23
Redelivered: 2012-09-12
Old 05-12-2013, 01:24 PM
Mein Auto: 335
i went to Continental dealer (discount tire) , they told me there is no warranty and must be replace.
i asked my BMW dealership , he told me that he offered me to buy tires warranty when i bought the car and i declined.
Old 05-12-2013, 01:51 PM
Yobyot's Avatar
Mein Auto: F30
You really are a rube, eh? You asked the salesperson? You haven't bothered to open the tire warranty CD but you are happy to take the word of the salesperson?
Good luck to you.
Old 05-12-2013, 06:28 PM
Mein Auto: 335
Good luck to you.
move on , already fixed the tire for 20$
i asked what brand and model of tires to replace my winter tires
