Old 05-19-2013, 11:32 AM
4dreuropean540i 4dreuropean540i is offline
Mein Auto: 99 540i/6
Question *Pic Q* Pitman arm...loose steering
Ok heres the issue, last year I replaced all the front suspension components with Lemforder with the exception of the centerlink. Ever since then and even before then the car felt loose and would have some slack in the steering wheel while driving in a straight line.
I have searched the issue and found that my pitman arm nut might need some tightening but does anyone have a pic of the arm itself and the loose nut in question? Any help would be appreciated thanks.
-Ryan
1999 540i/6
Dinan: intake/exhaust/chip
Bilstein B14 PSS
Old 05-19-2013, 01:03 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
If you have more than 100k on the car, the tie rod ball joint at the pitman arm is probably worn out. The spline to which the arm is connected to the steering box is so tight that one needs a puller to remove it. I very much doubt the nut is loose.
Put the car on ramps, have someone rock the steering wheel back and forth. and individually grasp each joint connected to the tie rod. You'll be able to feel the movement at the ball joint.
I'm on my third tie rod (don't buy Meyle).
Old 05-19-2013, 04:18 PM
Thanks for the info and the Meyle tip
1999 540i/6
Bilstein B14 PSS
