Old 05-11-2013, 05:42 PM
spmonki spmonki is offline
Mein Auto: Early 98 528i
clutch master cylinder question
Think i already know the answer to this question, but while trying to bleed the clutch in my car i can get a good solid pedal once then it back pressures into the master cylinder. I have tried all of the bleed teqniuqes listed elsewhere in this forum and nothing is working for consistant pressure. Does this sound like a bad clutch master cylinder to anyone?
Old 05-11-2013, 05:53 PM
16valex's Avatar
16valex 16valex is offline
Mein Auto: 530I/Stick Blown
Although the clutch shares the same reservoir with brake master cylinder it actually has a separated cavity, unless you fill the master cylinder to the very top the clutch will get none.
So fill it to the top then try to bleed again.
Old 05-11-2013, 06:02 PM
Have been ensuring it is full. Have tried multiple bleed techniques: gravity, pressure, vacuum, etc. I can get pressure for one pump of the pedal, but instantly lose it the next pump. When it lose pressure it pushes brake fluid back into the resivour. When it loses pressure it seems like i feel a small pop.
Old 05-11-2013, 06:11 PM
16valex's Avatar
Yes, it does sound like the master cylinder one-way washer is toast.
Old 05-11-2013, 06:14 PM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
While there are 2 cavities in the reservoir, the clutch master cylinder uses a high connection to prevent a clutch hydraulic leak from affecting brakes. I agree it sounds like internal leakage at master cylinder. Have you changed any hydraulic parts recently?
Old 05-11-2013, 06:18 PM
Thats what i thought. Yay more new parts. No i havent put any new parts into the hydraulic system. Was hoping id luck out with reusing the donor car parts. Should have known better, and picked up new hydraulics when i bought the new clutch.
Old 05-11-2013, 06:20 PM
And thank you.
