Old 05-12-2013, 09:17 AM
DjAikonX3 DjAikonX3 is offline
Mein Auto: 2000 BMW 323i E46 Black
TPMS Light blinking then staying on, All pressure is correct
Hello,
I hav recently changed tires on my 06 X3 and the tpms light stays on after blinking for a while as soon as i startup the car, i have tried resetting using the button and following the instructions and is not making it come off what could it be? is there a way to reset the whole computer maybe? so everything resets again? please help
Old 05-12-2013, 05:29 PM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Re: TPMS Light blinking then staying on, All pressure is correct
Have you ever had your tps sensors in the tires replaced? They typically only last 5-7 years on average.
Sent from my ADR6350 using BimmerApp mobile app
Old 05-12-2013, 07:27 PM
Mein Auto: 2004 X3 2.5i
Assuming you definitely have TPMS and not FTM (not all '06's did - just the late model year ones I believe) maybe installer damaged one of the sensors.
- if it started blinking immediately after the install, ask them if they did anything to try and re-initialize it themselves (some tire shops do, some don't)
- other than reducing psi in all tires to about 15, filling to 32 and trying the initialization again, I can't think of anything else other than having it hooked up to a BMW GT1 computer for diagnosis.
Old 05-13-2013, 03:51 AM
No the sensor have not been replaced just the tires,
what is the most inexpensive resource to get this sensors? i saw ITM? are those good?
also i will try lowering to 32 psi and see what happens, i really appreciate the response
Old 05-13-2013, 05:09 AM
Mein Auto: 2009 X3
Never heard of that company. When in doubt go oem. But have your car checked for codes before you replace the sensors, I think there kind of pricey.
Old 05-17-2013, 05:52 AM
So lowered the PSI to 32 and nothing light is still on, i guess i will have to take it to the dealer and see what they find - Thanks guys!
Old 05-30-2013, 03:03 PM
Ok so i bought the sensors and valves and had Tire Discounters put them on reset it the tpms light on the light is still on is there something special needed to be done when replacing this sensors other than doing a normal reset??
