Old 05-13-2013, 08:20 AM
trevinski trevinski is offline
Mein Auto: 2004 bmw 745li
downshift clunk, 2004 745li
2004 745li. Has anybody been able to fix this downshift clunking problem. Had the car at the dealership and they reset the adaptation codes and said the clunking should be gone after a couple of weeks. Although I don't drive the car much it still has not gone away. Don't like driving the car when every time you come to a stop you get that nice "clunk". Anytime anybody's in the car they ask "what the hell is that?". Tired of trying to explain. PLease help, anybody?
Old 05-13-2013, 08:27 AM
08750i 08750i is offline
Mein Auto: 2008 750i
Check your Guibo?
Old 05-13-2013, 08:38 AM
guibo coupling
mechanic said the coupling was fine
Old 05-13-2013, 08:40 AM
Changing the Guibo helped mine. Also did the software upgrade, helped a bit too. Search the site, there's a way to reset he computer by stepping on the gas pedal for 20 seconds when car is off and key is in. Sorry, don't know the details.
Old 05-13-2013, 08:43 AM
guibo coupling
you wouldn't happen to remember what the cost was to replace the coupling do you?
Old 05-13-2013, 08:52 AM
Was under CPO warranty, sorry don't know. But they do get chewed up and make that "clunk" sound when they're bad.
Old 05-15-2013, 09:28 AM
sharland sharland is offline
Mein Auto: 2002 e65 745i
I had mine done in the UK and it did make a big difference. I also had a small oil leak from the transmission so had the sump/filter and oil changed. I believe it cost around 150 to get the guibo changed.
Old 05-15-2013, 02:15 PM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
It's so easy to change did mine myselfClick image for larger version
Look how bad mine was!!!
I also drop the tranny to fix a small leak
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
Old 05-15-2013, 02:18 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Re: downshift clunk, 2004 745li
Did you have to drop tranny for the guibo? How long did it take? Thank you
Old 05-15-2013, 02:22 PM
rideme2's Avatar
rideme2
No need to drop tranny, I had a small leak of antifreeze, there a gasket there. It took 3hours. But u will need a lift. The exhaust needs to come down all plastics.
