Old 05-13-2013, 05:19 PM
mikesevel's Avatar
mikesevel mikesevel is offline
Mein Auto: 328i convertible '08
E93 radio problem...advice?
MY '08 CPO 328i E93 has an intermittent radio problem. At times, from cold start, it will not come on for at least one hour of driving. The screen shows the station or CD but no volume. Dealer sez CPO does not cover radio. Agree? Anything I can diagnose myself and fix?
Mikey
New Braunfels, TX
Old 05-13-2013, 05:31 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Have you by any chance tried turning the radio off then on again, or even turning the car off then on again? I know it sounds crazy, but I've had a very intermittent issue where my USB drive either isn't recognized or even more mysterious, can't remember where it was when the car turns off. When I start the car up, a particular song will be playing. I drive to work (10-12 minute commute). I'll get in the car at lunch time and the USB comes back on at the song it started with when I got in the car to leave for work. I've come to believe that BMW sound systems all have little ghosts in the machine as an incentive to turn off the radio and listen to the car.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 05-13-2013, 05:39 PM
Salvator's Avatar
Salvator Salvator is offline
Livin' like Larry!
Mein Auto: 2007 328XiT; 2008 328 CiC
Perhaps it is a software update... Ought to be cheaper than a new radio...
http://www.bimmerfest.com/forums/sho...rmittant+radio
Old 05-13-2013, 08:59 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Check the battery first.
If its on the original and the car sets awhile or is not driven far
the battery could be bad or at a low charge state.
The IBS system has the ability to turn non essential stuff off if
the battery is low . This can cause weird stuff to happen. If the battery
is low it will usually be accompanied by longer crank starts.
So the reasoning is after you have driven the car awhile the battery has enough
charge and the IBS allows the radio to turn on .
For a more detailed explanation of the IBS read the following link.
http://www.bawarec.ru/manuals/3er/e9...3er-e90-12.pdf
You did not mention if you have Idrive/nav or the normal radio.
(I know you said screen )
http://www.e90post.com/forums/attach...2&d=1260829447
Old 05-13-2013, 09:07 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
I've had the same problem. I thought it was due to having a 500gb hard drive on the USB port, which is not a BMW recommended configuration. But apparently it's not.
It's even worse when I'm 2 hours into a 3 hour audiobook and the stereo looses its place.
Mikey, try rebooting the Idrive by holding down both Eject buttons and the volume/on/off knob at the same time. It may help.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
