Old 05-14-2013, 10:13 AM
magicautocenter magicautocenter is offline
Mein Auto: 2003 745il
need help removing a starter on E65
engine wont start. it only make a clik sound. I need help on how to remove the starter to tested. if any body has done this, can u please help on the steps on how to remove it. thanks
Old 05-14-2013, 11:21 AM
pedro2u pedro2u is offline
Mein Auto: 745i
Here's the TIS file for starter removal
File Type: pdf replacing starter motor (N62, N62TU).pdf (225.2 KB, 711 views)
Old 05-14-2013, 04:37 PM
SuperSnoop's Avatar
SuperSnoop SuperSnoop is offline
Mein Auto: 2007 760Li
Tap it with a broom stick. If it starts after that, the starter is on its way out.
Could also be the battery or IVM. with the n73, you have to drop the exhaust manifold to reach the starter.
Old 05-14-2013, 04:52 PM
Thanks for the info.. Is there another file like this where it show the hole process from the start.!!! I try taping on the starter but i could only hit the silinoid. I could not tap big fat part of the starter or is the same.!! When tap it did not start only click. I just got the car like that from an auction. It was park for sometime , dont know how long but iam guessing about 2 or 3 month maybe more. It also has the engine malfuction light on. They sold me the car as a run and drive but when i got home it did not start. I try jumper cables but no luck. So i put a new battery and it on click like before. Is there any way i can test the ivm and n73?? Were are they located and whats there fuction?? Thanks
Old 05-11-2014, 12:54 PM
nida.dilo nida.dilo is offline
Mein Auto: 745i
Were you able to solve this? I am having the same issue. I have replaced the ivm next looking to do the starter. Any instruction.
