Old 05-14-2013, 01:59 PM
rrinas rrinas is offline
Mein Auto: 2007 BMW 323i
Oil level sinking fast!
I just bought this 2007 bmw 323i about a month ago... I managed to put on about 3000km since then (all easy driving). I noticed the oil level was full when I bought the car, and now its showing there is only a quarter left.. The car runs perfectly, and there is no sign of oil being burned... Is this common?
Old 05-14-2013, 02:04 PM
BiHoTTo115's Avatar
BiHoTTo115 BiHoTTo115 is offline
Mein Auto: 2006 330xi
Common, sure, but pop your hood and check the oil filter housing, to make sure there's no soot around it. Could be a bad gasket. Easy replacement job, and cheap.
Here's a pic I found online:
2006 330xi | 6AT | Navi | Premium | Cold Weather
Old 05-14-2013, 02:59 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
You mean idrive showing 1 green bar? I don't think that means 1 quart left. Doesn't this car take 7 quarts total? a months from 5 bars to 1 bar is a bit fast. Usually takes months to go to 3 bars.
Old 05-14-2013, 03:03 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
If it's a non-iDrive car and you're using the dash display, "MAX" is 7 quarts and "MIN" is 6. If you're at or below the "MIN", you should put in a quart. Between "MIN" and "MAX" is fine.
Sounds like you're using a quart every 2500 miles or so. A bit heavy, but you also have a limited amount of precision in the gauge. Add a quart when you hit "MIN" and then record how long it takes you to hit "MIN" again.
BiHoTTo115's Avatar
Yep. It's basically one quart, what the iDrive is showing. When it's at the bottom, it's missing roughly a quart.
Old 05-14-2013, 03:41 PM
Yah, it's a non idrive car.. I just don't want to add a quart, only to find out that it really didn't need it.. I can't figure out where the oil is going!?! It's clean in the engine bay, and there is no black smoke coming from the tail pipe...
Old 05-14-2013, 03:48 PM
BiHoTTo115's Avatar
Never actually add a full quart when it says to...add half of the quart container. I guarantee you it'll show full on the iDrive screen.
The computer's aren't THAT accurate to tell you that EXACTLY a quart is missing.
Old 05-14-2013, 03:59 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
Read your manual so that you understand what the system is telling you.
Then wait until you're a quart low to add. KEEP a record book in every car, and note the mileage of every repair, every oil and filter change, etc. That's the only way you'll get a picture of how the car is working.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 05-15-2013, 08:52 PM
I was looking around the oil filler cap today, and noticed a bunch of crud in there, Im thinking the oil was coming out from under the cap.. I noticed there is a rubber seal under the cap, which is loose and not doing anything, what is it there for? The cap makes a click sound now when I close it.
