E34 (1989 - 1995)
Old 05-17-2013, 02:24 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Originally Posted by 5seriesman View Post
Good news! I got off work last night and as soon as I got home I pulled the back seat and unhooked my battery and left it sit like that all night, I woke up this morning reconnected my battery and started the car, It ran like a charm!!!! I let it idle for a while and I could feel a slight shaking and the idle getting worse but not much soo this tells me the o2 sensers are bad cause they kick in when the car starts to heat up am I correct?
Sent from my SAMSUNG-SGH-I997 using BimmerApp mobile app
You are indeed correct that the O2 sensors don't affect the engine until they reach a certain temperature. Your symptoms do seem to point in that direction, but it's kind of like the wind blowing in a direction without gettng the proper diagnosis. It's pretty likely that replacing the O2 sensor will fix the problem, but there's a pretty decent chance that it won't.
Anyway, your car may be in need of a new O2 sensor anyway, I'd just hate to see you replace it and that not be the problem. IIRC, you are the one that has the CEL bulb not functioning, correct? I would encourage you to get that replaced as well because the stomp test tells us so much when a problem like yours comes up and ..... it FREE
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-17-2013, 02:40 PM
5seriesman 5seriesman is offline
Mein Auto: 1991 bmw 525i 5 speed
Re: Bad sensor??
I hope that's my problem also cause oxygen sensers isn't cheap lol But I'm 90% sure that's my problem and yes my bub went out of my check engine light how would you replece the bulb? I never had to go about doing that before.
Old 05-17-2013, 02:59 PM
BMR_LVR's Avatar
Humble E34 lover
You would have to remove the instrument cluster. I have never done it, but from what I read, it can be frustrating getting the cluster beyond the steering wheel without removing the wheel, but it can be done. It is possible that, due to the location of the CEL on the cluster, perhaps the bulb can be replaced without fully removing the cluster
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-17-2013, 03:12 PM
Re: Bad sensor??
I have an m tech steering wheel in the car UN bolt it and its off I'm hoping its just a pull out bulb and re connect the wire from the back of the instrument cluster lol
Old 05-17-2013, 07:30 PM
BMR_LVR's Avatar
Humble E34 lover
Do you have an air bag? If so, make sure to disconnect your battery before you take the wheel off or you will get an SRS light and it has to be reset with a special tool.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-18-2013, 03:43 PM
Alnlesley Alnlesley is offline
Mein Auto: 91'bmw ac schnitzer
I could be wrong but dont the m50 engines require premium gas to run at there best? Maybe you have dirty injectors or bad gas..?
Old 05-19-2013, 05:23 AM
burbankE34 burbankE34 is offline
Banned
Mein Auto: E34
Well, why don't you just pull the O2 sensor relay and find out instantly ? Its one of three relays in the DME box behind the front right shock tower. Pull the other two and the car won't start, they are the fuel pump and main relays, this is the third one and the car will still start with it pulled. You don't have to reset error codes if this is the problem it will be fixed instantly. Just the symptoms not the o2 sensors of course.
Old 05-19-2013, 05:25 AM
Banned
Mein Auto: E34
Well I guess it is a good idea for you to get the CEL bulb fixed, how else will you know if you need to check the engine ? haha
