Old 05-14-2013, 04:45 PM
zachiepie zachiepie is offline
Mein Auto: 1997 328is, 2001 750is
A/C high pressure switch not on
Hey guys. As the weather warmed up, I found my A/C isn't working. I found that the high pressure switch isn't even turning on; as it's not powering the compressor, and I can actually jump the compressor into giving me cold air.
Is there a reason why that switch won't activate? I occasionally get a message to check coolant level (level is fine, sensor must be bad), could that turn that switch off? Or maybe there is a reset procedure? I can't even find a schematic. Hmmm. Maybe it's not that different from an e39...
Old 05-14-2013, 09:25 PM
Mayorchuck Mayorchuck is offline
Mein Auto: '96 740iL
Refrigerant, ambient temperature and coolant temp can all affect the compressor. My limited experience with that issue was usually low freon. Not sure if the link below will work. Has more detailed info. It's a PDF that give more specifics on the numbers.
http://www.google.com/url?sa=t&rct=j...,d.dmQ&cad=rja
Old 05-15-2013, 08:54 PM
No dice on that link!
Old 05-15-2013, 09:00 PM
It's a .pdf I have bookmarked. When I click on it it downloads the pdf and opens it. Let me try it a different way.
http://www.bimmerboard.com/members/r...38.pdf***8206;
http://www.bimmerboard.com/members/r...IHKA%20E38.pdf
Old 05-16-2013, 04:13 AM
Ah ok, my Surface Pro opened it. Thanks! While I don't see anything I can immediately use, I'll dig through it. Looks like a ton of good information.
Old 05-16-2013, 06:25 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
If the system is low on gas, the pressure switch will not operate the compressor
Old 05-16-2013, 12:05 PM
High side had plenty of pressure, not sure about the low since the compressor wouldn't turn on unless I jumped it. And when I jumped the compressor, the air blew pretty cold.
Old 05-20-2013, 07:15 PM
Umm so I think I solved it. I turned on the defroster, then hit the snowflake, and the compressor engaged. Weird huh.
Old 06-09-2013, 11:27 AM
So it turns out that the compressor isn't turning on now, even though the snowflake light is bright. Any other ideas?
HTML code is Off
