E34 (1989 - 1995)
Old 05-14-2013, 05:46 PM
krzekool krzekool is offline
Mein Auto: '98 740 94'540 and a M6
Smile Looking to put a 4.4 in a 94 530 touring.
I've come across a good deal and Looking for info/specs to install a 4.4 engine into the wagon.
I already know that the blocks are the same as well as the engine wiring harness is the same. However can I use the existing tranny and the computer?
Can I use the existing engine computer or do I need to use the 4.4 computer and if so will run into the problem of the EWS coding issue?
If you know please let me know....Any info will be quite helpful in deciding if it's worth doing the swap.
Old 05-14-2013, 07:41 PM
imae34driver imae34driver is offline
Resident e34 Racer
Mein Auto: 1995 540i SPORT /6 spd
This is just the way i look at it,
I would run an m60 manifold, throttle body ect to stay obd 1 and wiring and linkage is supper easy. Id run a 404 DME with a chip tuned for you from DUDMD or something.
This way you get the high flow of m60 manifolds, tuning ability of OBD 1 and the displacement of a 4.4.. The m60 heads bolt onto m62 blocks for high compression also..
As for vanos, idk how that will play into all this..
Also, just go with manual. dont swap motors and keep the lame trans..
fck jdm / fck honda
Old 05-14-2013, 11:57 PM
MySatinDoll MySatinDoll is offline
I'm from NJ. So What!?!
Mein Auto: What they Drive
Before doing any type of swap. There are 5 must haves:
1. Plan, objective, or goal (which ever you prefer)
2. Research every aspect of the build
3. Mechanical knowlege and experience.
4. Budget
5. Time
You will need all of these to complete the task.
I'd say go for it. It's been done with success.
The allure of a e34 540it is similar if not accurately depicted as the best of both worlds.
Google the swap or go to BF.C. You're bound to find info there or at least speak to those who had the pleasure of owning one.
Good luck
btw: (don't quote me) IIRC you'll have to change the driveshaft and/or output bearing, DME, and maybe some other things but for the most part it's plug and play.
And yes... Drop the slushbox autotragic and throw a 6spd in it.
_______________________________________
Content Writer - FCPEURO
95 e34 525 5 spd S52 Swap...Sold
01 e38 740i msport (under restoration )
Old 05-15-2013, 03:13 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
^^ great advice both of you
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
