Old 05-14-2013, 07:49 PM
Bet2238 Bet2238 is offline
Mein Auto: 2009 328i
Reposting Service soon Engine Light
Hello!, two months after my warranty expired service soon light illuminated. I thought it was a maintenance light coz i knew i'm due for an oil change but that's not it after an oil change and reset it's still there so i decided to buy an OBD2 (innova3030). My initial code was p0050 (bank 2 sensor 1) drove it for a couple of days and i've noticed that my idle rpm is not steady and hesitant to start. Scanned it again and now showing a bunch of code such as p0300,p0304,p0305,p0306,p0050,p1017,p1014,p0171. I replaced the oxygen sensor(Bank 2 sensor 1) knowing that it could be the problem since it was the first code that showed up ( used bosch ) after the replacement all the code are still present. I use the obd2 that i bought to clear but i couldn't clear the code please help any thoughts and ideas are appreciated .. Thanks
Ok 5 out 8 codes are now gone. The remaining codes left are p1017,p1014 and p0171 what u guys think. What could be the problem. Please help
A response fron Fast Bob:
It normally takes a number of driving cycles (of 15 miles or more) before the codes delete. This can take up to a week.
Thanks for the reply fast Bob i appreciated that. I drove it for a couple of days now the idle rpm is pretty stable it stays at 700 rpm, still have a little difficulty starting, the 3 codes are still there, and i have noticed i can hear a high pitch sound when decelerating (once in a while)and my gas i think it's burning too much gas for 50 miles I used atleast 3 gallons do you think it's a vacuum leak? If so, do you think i have two different problem?
Old 05-14-2013, 09:17 PM
fb88 fb88 is offline
Mein Auto: 2014 X1 xDrive28i
http://engine-codes.com/p1014_bmw.html
http://engine-codes.com/p1017_bmw.html
http://engine-codes.com/p0171_bmw.html <--- use CRC MAF cleaner on your MAF sensor to see. Also has the air filter been replaced?
http://www.amazon.com/CRC-05110-Mass...RC+MAF+Cleaner
Old 05-15-2013, 11:40 AM
Thanks fb88 i looked at the MAF before but i didn't clean it coz it looks clean as per air filter i haven't replace it yet. Once the MAF is cleaned and filter is changed and still the same do you think i need to replace the(oxygen sensor)bank 1 sensor 1?
Old 05-15-2013, 06:53 PM
How many miles is your car? I don't think you can tell by naked eye if MAF is dirty. Might as well replace air filter if it's overdue.
I don't know about the oxygen censor because I only fixed my problem w/the MAF cleaner. (fuel too lean, hesitation, stalls when stopped)
I'd think oxygen sensor would have its own code.
http://www.e90post.com/forums/showthread.php?t=357827
Old 05-15-2013, 07:42 PM
I have 52K on mine, I will clean my MAF sensor and I will post the outcome.
Old 05-21-2013, 06:28 PM
I finally send my car to an indy mechanic and i was told that the problem is the valvetronic eccentric shaft sensor. but when he opened the valve cover he found some wear and tear on the gears and some metal shaving now he's talking about replacing the cam shaft. Is it really possible for that gear to worn out?
Old 05-21-2013, 07:20 PM
How much is he asking to replace the shaft sensor?
vs replacing cam shaft?
what if you don't replace the cam shaft?
Old 05-21-2013, 09:05 PM
the mechanic wants me to see it, so tomorrow i will check it out then we will make a decision
Old 05-21-2013, 11:19 PM
1zamboni 1zamboni is offline
Mein Auto: 2013 E93 & 2014 F30
Mine came on today and my SA thinks is the shaft sensor might gone bad, will keep you posted when I drop the car off on Thursday for diagnostic.
2014 F30 335i Melbourne Red
2013 E93 M3 Melbourne Red
2012 E93 Space Gray (Retired BMW buy back)
2009 E82 ( Sold )
2006 E90 ( Sold )
2001 E46 ( Sold )
My next vehicle would be a Zamboni
