Old 05-14-2013, 09:07 PM
OCEANSIDE,CALI OCEANSIDE,CALI is offline
OCEANSIDER..SDIEGO.
Mein Auto: titanium02,745LI,F-loaded
please help.car feels like its running hot.
hello everybody.well i have a question bout my car.it seems that when we drive the car for about an hour or so the car feels like its really really hot.no lights pop up or anything like that.and also my cooling fan duznt come on after the long drive.ive noticed that it smells like coolant but therers no smoke or anything like that.you can feel the heat coming from under car when its iddling n i touch the hood and it is extremely hot.any ideas what i should do?i have a 2002 745 li...and also when i turn car on it iddles ok,but after we go and then come to a stop,it feels like its iddling pretty high.i sometimes have to pull over n turn car off and wait and see if the iddling comes down back to normal..any ideas are surely appreciated down in san diego...thanks everybody.....
Old 05-15-2013, 06:18 AM
pedro2u pedro2u is offline
Mein Auto: 745i
You can check your water temperature while you're driving by pulling up the hidden menu. It requires you to unlock a screen to read it.
Here's how (doing this from memory so bear with me):
With the engine running, hold down the trip reset button for about 10 seconds until a menu appears in speedometer, then release. Now press the trip reset repeatedly until you step through the menu to Unlock (I think it's #19). Now hold down the trip reset until a new menu appears in the tach. Your unlock code is the last 5 numbers of your VIN added together (so if the numbers are 12345, your code would be 15). Push the trip reset repeatedly until it counts up to your code and release. Then hold down the trip reset until it takes you back to the menu in the speedometer. Press the trip reset until you get to Sensor Data (#7). Hold that down until the menu appears on the tach.
Water Temperature should be the top one in the list
Hope this helps. And it takes much longer to type this than it takes to do it
Old 05-15-2013, 04:14 PM
OCEANSIDER..SDIEGO.
hey pedro2u,thanks for the info.i really appreciate it.soon as i get home im gona try that.once again,thanks a whole lotttttttt
Old 05-15-2013, 06:34 PM
Mein Auto: 745i
Glad to help. One of the many things learned right here on the fest!. Hang around, participate, and you'll learn a lot from your fellow 7 owners! Then help someone
