Old 05-15-2013, 07:56 PM
birdman15 birdman15 is offline
new to BMW life
Mein Auto: 2008 328xi
OBD II scanner?
2008 328 xi
does it have a OBD II socket or a different socket to read codes?
my check engine light just came on tonight and I have a OBD II scanner.
thanks in advance to all. It is our 1st BMW so we are learning.
Old 05-16-2013, 03:36 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by birdman15 View Post
2008 328 xi
Mine's below to the left of the steering column.
Generic OBDII scanners very limited - you need THIS
Old 05-16-2013, 04:45 AM
new to BMW life
excellent thank-you!
My OBD II reader is pretty good so I will try it 1st but if not I'll be grabbing one of those Bavarian Technic Cables for sure.
here is a question. Most reader require you to put the key into the on position but do not start the vehicle. How do you do this with a BMW? seeing there is no on position for the key fob? or is it when you put the fob into the receptacle it is considered in the" on position "?
thank-you again for the info.
cheers
Old 05-16-2013, 08:21 AM
Hit the START button once briefly. Dash lights up; engine does not start. FYI
Old 05-16-2013, 08:29 AM
new to BMW life
u sir are a excellent source of help!
Old 05-17-2013, 07:03 AM
wattage wattage is offline
Mein Auto: 2008 328I
With a manual you can hit the start button without depressing the clutch. Not sure about the auto but probably the same if you don't have your foot on the brake.
Old 05-17-2013, 07:08 AM
new to BMW life
I tried it last night just briefly hit the start button and it worked. tap it real quick. No brake pedal
Old 05-17-2013, 07:14 AM
bighorns's Avatar
bighorns bighorns is offline
Evil cider brewer
Mein Auto: E92 335i M Sport
Yes, on AT hit start button, no foot on brake. I think I will be ordering one of these soon!
