Old 05-16-2013, 02:36 AM
niterunner niterunner is offline
Mein Auto: BMW 750Li
Small problems with my Night vision on 750Li (NiVi)
Hi all,
As you can read in the header, I've got a small problem with my night vision.
When I activate the function I can see object moving and heat sources but the image is not perfect, it's "flickering", like a bad reception/disturbance on a TV with weak signal.
I have tried to read about this on the internet but found nothing on this problem.
Personally, I don't think there is something wrong with the camera because it's projecting the image but where the flickr/disturbance is coming from, I don't know
Has anybody have the same problem?? Or similar??
Old 05-16-2013, 01:30 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
many people have had problems with the camera and most of the time it requires replacement of the stupid camera which is upwards of 2K. I'd check all the wires to and from the camera and ensure that they are all plugged in properly.
Furthermore, check the rear left area of your trunk (inside the little compartment) and look for any sort of sticky fluid, dampness, discoloration, etc. LOOK WELL into the area. I had something similar happen but it was only on my map screen and on no other menu. Hydraulic fluid for the trunk leaked into the video tuning module and the navi drive thus causing it.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2010 Honda Accord EX - Basque Red/Ivory
lOE Fog Lightsl
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
Old 05-16-2013, 03:17 PM
Thanks for the replay, I will get on it as soon as possible.
Did you have to change the module or did it get fixed??
