Old 05-16-2013, 05:59 AM
mdr411 mdr411 is offline
Mein Auto: 2007 328xi
Car died on highway, second time this week
Monday I was driving to work, right before I arrive the red battery light came on. I went back inside and googled it, guessed either bad battery or alternator. Started the drive one, after 10 minutes all sorts of warning lights start coming on, car starts getting sluggish then dies. I noticed the dash lights were getting dimmer and the cr slowly lost all power. Got it towed home and replaced the alternator. Now the battery was dead do I jumped it and everything seemed fine. Then on my test drive the power steering lock warning came on red. So I brought it to my guy and be could. Find anything wrong(see other post). When I started it up to brim it home I noticed the light was gone...? So I figured I'm good to brig the car to work today. Wrong. I'm 5 minutes from work, I had made it 45 miles when the dash began lighting up warnings like a Christmas tree. First the abs, then 4x4, the. Some circle with waves, there were more. Then the car died. I pulled it to the side and heard a clicking sound coming from the glove box/ fuse area. I'm in the tow truck now bringing it back to the shop. Wtf...btw way it's a 2007 328xi with 130,000 miles. I've always loved it but I'm beginning to see red! What's going on? Bad battery? Bad alternator? I bought one from autozone, i know I prob should t have but I was able to get it that day.
Old 05-16-2013, 06:06 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
See this http://www.bimmerfest.com/forums/sho...d.php?t=418907
BMW CCA Member 454031
Save the manuals
Old 05-16-2013, 06:11 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
OK there's definitely a lot of frustration in your post, and it is hard to follow.
1. I never got whether or not you replaced your battery?
2. The alternators from autozone come defective from the box more times than you will accept to believe.
3. Sounds like it may be a simple fix, but you have to work to figure it out. First hing is to check if you have at least 12V between the battery terminals. Second is check the voltage dip while you are cranking the motor. And third, check the voltage while the engine is running (should be about 14V).
After this is done, you may have to hunt for a bad ground.
Old 05-16-2013, 07:10 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Have you had your car in for the battery connector recall?
Old 05-16-2013, 08:17 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
First things first mdr-man. Do THIS
Old 05-16-2013, 08:59 AM
Tom K.'s Avatar
Tom K. Tom K. is offline
And have both the IBS and JBE checked out by a BMW tech.
Tom
Old 05-18-2013, 03:43 AM
It ended up being a bad battery.
