Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings added style and new features to the BMW's mid-sized SUV. Talk about the BMW F25 X3 with other X3 owners now!
Old 05-16-2013, 02:15 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
More Power!
So I have spent many years adding power to my 335i and admit to not being able to leave things alone t ypically. First step on the X3 was to recode all the cool features I could (available in other threads), but I also decided I could use a little more power- not crazy stuff like the 335i, but just a little more kick in the pants.
Since there is not a lot available for the X3, I settled on the Juicebox State 1 from Burger Motorsports, I had used their JB4 at one point on my 335i, but switched to a GIAC flash eventually, but not for any other reason than the flash could do a little more in combination with my other modifications.
I received my Juicebox in 2days and the installation was pretty easy, just 2 plugs it intercepts (one is under the airbox though, so a bit of work to get to). The only issues I had with the install was that the instructions say to put it in the top of the ECU box for most models, but the X3 does not have an ECU box under the hood, so no good waterproof area to put it. I pinged Terry at Burger Motorsports and he suggested putting it in a watertight bag like a ziplock or something and then just put it somewhere out of harms way under the hood. I did not love the suggestion, but the only other option would be to buy an extension cable and move it into the passenger compartment which is a lot of work.
So I ended up wrapping it in a bag and then electrical taping it very well and finding the driest spot I could.
That being said, it works great, gives a noticeable boost in power for the money and otherwise drives just as smooth as before with just a little extra kick. Very happy with the product for the money.
Rob
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 05-16-2013, 03:19 PM
ponti33609's Avatar
ponti33609 ponti33609 is offline
Mein Auto: Moto Guzzi
More Power!
Am I seeing 30HP for $100 bucks? Seems like least costly is the best bang for the buck? Is that what drove your decision?
MPG effect or does it not matter to you?
Pretty cool.
Best Regards,
Bob
Old 05-16-2013, 03:39 PM
scottjays scottjays is offline
Mein Auto: 2014 BMW X3 35i M Sport
Rob
2016 BMW X5 35i X Line Space Gray, Mocha Nappa Int, PureWood. Driver Assistance, Premium, Dynamic Handling, Light Pack LED, HarmanKardonSound Lux Seating w/ MultiContour, Dynamic Damper, Cermanic Ctrls, ACC StopGo. MODS: M Sport Steering Wheel w/Paddles Coded.
Old 05-16-2013, 09:32 PM
Pretty cool.
Mpg was not a big consideration, but seems relatively unaffected.
I did the JB Stage 1, $379 but 50 hp/60 torque, a good deal for the additional power and quick and easy to install and remove. One other advantage is it has resale value, where an $800 flash cannot be resold.
Old 05-16-2013, 09:47 PM
ponti33609's Avatar
More Power!
This must make our warranty void if known?
Best Regards,
Bob
Old 05-17-2013, 12:20 AM
Toast. Toast. is offline
Mein Auto: X3m, B8 Avant
Only voids warranty if they can prove the the tune is the cause of the problem. Even if you remove JB4 before bringing into dealer they can look at logs and tell if you were tuned.
I've read in a different thread that JB4 tune will not control variable valve timing, VANOS and other critical engine components like individual cylinder ignition timing???
Old 05-17-2013, 01:17 AM
Vortec4800 Vortec4800 is offline
Mein Auto: 13 X3 35i MSport, 09 135i
I also have the JB3 in my 35i and it's great. Easy install like you said once I tracked down the connectors. I found for the X3 only using 2 of the 3 plugs worked best. I put mine near the cabin filter on the passenger side, dremeled out a little wire hole and it sits nicely there.
What settings are you running yours at?
Old 05-17-2013, 08:17 AM
The warranty thing depends - it can only void your warranty if they can prove it caused the issue (magnuson moss act), so if the motor explodes, it could be a bit painful if they know you had it tuned. That being said, it also depends on the dealer/technician - some, like mine have no issue with it, others like to try to deny warranty work at the drop of a hat. As for detection, this is a mild tune and just basically lies to the ECU about that the boost sensors are seeing, so it acts like the car already does at high altitude by increasing boost a bit within factory specifications. Since it lies to the ECU about what the boost is really at, the logging still sees the boost at normal levels. As for things like valve timing and Vanos and timing, the car is still controlling those, those issue come in more when you are going way above what the factory maps can handle with the boost and then need to control fuel and timing. Since it is within the limits of the factory software for max boost, it does not trip the tuner or high boost codes. That being said, I also have the ability to read all the codes and shadow codes and clear them if any were ever set.
If anyone is familiar with the turbo tuner for the N54, that is basically what this is doing.
Obviously there is some amount of risk, however small that you are modifying your vehicle and BMW may be able to deny coverage or give you a really hard time if they want to, so each person has to decide if the risk is worth while or not.
Rob
Old 05-17-2013, 08:20 AM
Mine is just the Stage 1, not a JB3 or JB4, so no settings and only uses 2 plugs.
i was going to try to put it near the cabin filter, but it seems a bit too short the way I had run the wires to get it there, so I ended up butting it on the drivers side tucked under the fender out of harms way as much as I could get it and well water proofed.
Rob
Old 05-17-2013, 11:17 AM
Rob
The JB3 is considered Stage 1 for the N55, you can adjust the settings if you get the USB cable for it but it isn't included.
Old 05-17-2013, 11:37 AM
Ah, good to know!
Old 05-28-2013, 10:01 PM
04prox2 04prox2 is offline
Mein Auto: x3
[QUOTE=Vortec4800;7590710]I also have the JB3 in my 35i and it's great. Easy install like you said once I tracked down the connectors. I found for the X3 only using 2 of the 3 plugs worked best. I put mine near the cabin filter on the passenger side, dremeled out a little wire hole and it sits nicely there.
which 2 of the 3 are you using? Ive had mine for 2 years and have used all 3. Only a couple of times it has thrown a code. I can clear them myself. Recently it has thrown my x3 into limp mode a couple of times, never did that last year. I remove for the winter.
Old 05-29-2013, 12:01 AM
I use the very first one (which I believe is the intake pressure sensor) and the very last one which controls the turbo wastegate. The middle one that plugs into the MAF I leave disconnected.
