E34 (1989 - 1995)
Old 05-16-2013, 01:23 PM
kennyspeed kennyspeed is offline
Mein Auto: 528i
Need your help_How to disconnect the Trans Wire Harness Plug
Need your help as I have a trans fluid leak at the Wiring Harness plug into the trans. I want to change the two o rings, but don't know how to unplug the harness. I can remove the clip but need to unplug and then push the receiver side through the trans to get to the o rings. Can someone tell me the trick to disconnecting the harness. Photos attached. thanks E34 540i
Name:	Trans harness 1.JPG
ID:	376847   Click image for larger version
Name:	Trans harness.JPG
Old 05-17-2013, 08:03 AM
Mein Auto: 528i
Got it done
Where's the love. Got it done, just had to twist a little harder.
Old 05-17-2013, 08:06 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Hey Kenny. The love's here, we just didn't know the answer to your question.
Glad you got it figured out and posted the solution Now others can learn from you.
Also, if that is on your 528, then that's an E39 and it may not be the same as the E34.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
