Old 05-17-2013, 06:31 AM
X3 Bimmer X3 Bimmer is offline
Mein Auto: X3
squeal noise by the rear after car shuts off
Hey all,
I am a new member on here. I just recently bought a used 2007 X3si with 39,000 miles on it. The car as of todays date runs like a dream. Very quiet and very smooth. However, Ive noticed last night that when I turn off the car I can hear a short squeal like sound coming from underneath the rear end somewhere. Its kinda hard to tell how far in the rear end its coming from. It sound as if like 2 pieces of metal rubbing each other with no lubrication.
Does anyones X3 make that sound when the car turns off? Could it be the exhaust/muffler? transfer case? please dont say its the transfer case
Any help would be appreciated it! Thanks all!
Old 05-17-2013, 07:24 AM
Mein Auto: X3
bump.. anyone after turning off your car you hear a sound coming from the rear end?
Old 05-17-2013, 07:31 AM
al_macaroni al_macaroni is offline
Mein Auto: BMW X5
Is you parking brake on? If my parking brake is on, sometimes when you get out of the car, it will rock and the (rear) brake will give a short metal on metal sounding squeak.
2016 X5 35d | Mineral White | Terra
2013 535i - ED, Oct 2012 | Cashmere Silver | Oyster/Black Nappa Anthracite | ZCW | Sirius | Air Blue 80
retired - 2008 X3 | Monaco | Sand/Black Light Poplar | ZAP | ZPP | ZCW | Xenon | Rear Fog
1988 Grand Wagoneer | Burgundy | Ghost Flames | 360 ci | Holley carb
BMW CCA #422951
Old 05-17-2013, 07:36 AM
Mein Auto: X3
Thanks for your reply. Sorry, I should have mentioned that I have an automatic transmission. No lights display on my dash, everything runs smooth and quiet. No idea where that sound is coming from. It sounds like its coming right underneath the back seat area. I am a rookie with this car, i dont know as much yet..
Old 05-17-2013, 08:55 AM
X3emist's Avatar
X3emist X3emist is offline
Mein Auto: 06 X3 Sport
Fuel pump
Fuel pump is the only thing I can think of that is back there.
2006 X3 Silver Grey/Black Lthr/Alum Trim/Sport Prem Pkg/Xenons/Servotronic/Prem Sound/Satellite Radio/Heated Seats/Carbon Fiber Pillars/Blue Tooth/Aux In/Cargo Net/Aluminum Pedals/V1 Hardwired
[SIGPIC]
Old 05-17-2013, 09:54 AM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Same here, sometimes I can hear my fuel pump running after shutdown. Makes sort of a whirring sound or a low hum for up to 1-2 minutes.
Definitely not a screech though.
It was mentioned here earlier, do you set your e-brake even though you have an auto tranny?
Is your driveway/parking spot on an incline/decline? Maybe its the sound of the hill hold function?? I don't know.
Old 05-17-2013, 01:01 PM
nightmareuki nightmareuki is offline
Mein Auto: X3
butterfly valve on the muffler
Old 05-17-2013, 02:00 PM
Mein Auto: X3
No. The parking brake was not engaged and no incline or decline. The car doesnt move when I turn it off. Soon as I turn the key off you hear the sound coming from underneath maybe near the muffler.
I know the transfercase in these cars are problematic but would the tranfercase make a noise after turning off the car?
Old 05-17-2013, 02:05 PM
Mein Auto: 2009 X3
Re: squeal noise by the rear after car shuts off
Can you have someone stand behind the muffler and watch/ listen to the butterfly valve?
Sent from my ADR6350 using BimmerApp mobile app
Old 05-17-2013, 02:07 PM
Mein Auto: X3
Grabby,
yes that was my plan as soon as I get home from work. I'll check it out then and post here later tonight......thanks....
Old 05-17-2013, 04:37 PM
Mein Auto: X3
Update,
Went home and had someone turn off the car for me and heard the noise right through the muffler. Im a rookie and know nothing about x3's but what is that valve like thing inside the muffler tips? I believe that made the noise. Is that normal? Thanks.
Old 05-18-2013, 11:53 AM
Mein Auto: X3
Bump.
Does anyones butterfly valve make noise when car turns off?
Old 05-20-2013, 06:36 AM
Mein Auto: X3
thats exactly what it is.. is it always supposed to make that noise when the car turns off?
Old 05-20-2013, 07:06 AM
Mein Auto: 2009 X3
Mine doesn't make a noise, but atleast you know it'd nothing major. I don't know how to fix it, maybe some penetrating oil on each hinge areas
Old 05-20-2013, 08:24 AM
Mein Auto: X3
i had the whole muffler replaced under warranty because of it. but ive read somewhere that its the vacuum line that gets insecure and causes it.
Old 05-20-2013, 08:55 AM
X3emist's Avatar
Plug the vacuum line with the old golf tee trick, don't ask, search this forum
[SIGPIC]
Old 05-27-2013, 11:16 AM
turbotom turbotom is offline
Mein Auto: 2007 X3 3.0si Sport Pkg
Fuel System Venting
I periodically hear that same noise emanating from the rear of my 2007 X3. It is the fuel tank venting. Yes I realize it's a closed system but the tank vents into a carbon canister and what you are hearing is the valve operating allowing pressure to bleed off of the fuel tank.
Old 05-28-2013, 06:03 AM
Mein Auto: X3
Hi. I figured out what it was. Its my butterfly valve inside my muffler. It opens everytime you turn off the car. It may be rusting or something that causes it to squeal like that. I never had a chance to try putting some grease on there.
Thanks for your input.
Old 05-28-2013, 09:15 PM
jpaavola jpaavola is offline
Mein Auto: 2008 X3 M Sport
What is this valve for? I am the second owner of my 08 X3 and someone before me cut the vacuum line. The valve is now always open.
Old 05-28-2013, 09:59 PM
Mein Auto: X3
exhaust velocity and sound
Old 06-01-2013, 08:30 PM
niceguymr niceguymr is offline
Mein Auto: 2008 X3
When I first read your post, I thought for sure it was the same thing that I was experiencing in this thread:
http://www.bimmerfest.com/forums/sho...d.php?t=584088
